Whirlpool Estate Washer won't spin with moderate to heavy load
5 replies to this topic
#1 Scherp
Scherp
  • 18 posts
Posted 12 September 2012 - 01:48 PM
I have a Whirlpool Estate Washer, that won't spin in the spin cycle with a moderate to heavy load. The agitator works and I can get it the basket to spin if I help it, but won't spin at top speed. I checkout the motor coupler and it looks good. There is a little grease on the floor under the right side of the transmission when looking from the front. Any idea what wrong?
I have gone over the washer 3 times and can't find a model number, this is the information on the front panel. If someone could let me know where to find the model number I would greatly appreciate it.
Whirlpool Estate
Heavy Duty Super capacity 8 cycles 4 combination
1/2 hp motor
Double Action Agitator
Self cleaning filter
#2 RegUS_PatOff
  • 30,221 posts
Posted 12 September 2012 - 02:08 PM
open Lid
model number on rear of Tub rim
How's the Clutch ?
something stuck between Basket & Tub ?
#3 Scherp
Scherp
  • 18 posts
Posted 12 September 2012 - 02:17 PM
The model number is TAWS800JQ1
There nothing stuck between the basket and tub.
I'm not sure about the clutch, since I can only see the out side of the clutch housing. There are particles on the top of the transmission housing. I can only turn the agitator by hand a quarter of turn counter clockwise. The motor is not attached. I do have ring of grease on the inside the cabinet.
Edited by Scherp, 12 September 2012 - 08:16 PM.
#4 Scottthewolf
Scottthewolf
    Senpai
  • 1,911 posts
Posted 12 September 2012 - 10:01 PM
The gearcase leaked oil on the clutch. Looks like you might have to replace both the gearcase and clutch, not a bad job, but the parts are rather expensive.
http://www.repaircli...?s=t-3360629-==
http://www.repaircli...bly/285785/2670
Scott Wolf
#5 Scherp
Scherp
  • 18 posts
Posted 12 September 2012 - 10:06 PM
I will take the clutch apart to see if grease did get into it.
#6 Scherp
Scherp
  • 18 posts
Posted 13 September 2012 - 04:47 PM
I took the transmission out and the clutch was dry, but worn and the transmission cover was leaking oil. I open the transmission and it still had oil in it and the gears looked good, so I replace the oil and resealed the cover tight using RV sealant. I replaced the clutch and washer worked on one load so far.
