KitchenAid KUDI02IRBL1 - Check Valve?
5 replies to this topic
#1 JoeIsuzu
JoeIsuzu
    Yamabushi
  • 78 posts
Posted 15 September 2012 - 03:39 PM
First, I'm not positive about the model number. I can't tell if there's an "O" or "0" in it. Judge for yourself.
Attached File  KitchenAid-Dishwasher.jpg   34.47KB   6 downloads
After running the sink for a while, water backed up into the dishwasher and all over the floor. Of course there was lots of stuff in the disposal and thus the water was not draining. I cleared the disposal, and the dishwasher was able to pump the water out on its own.
Isn't there a check valve that should prevent this from happening?
Thanks.
Jack
#2 vee8power
vee8power
    Kohai
  • 453 posts
  • Flavorite Brew:Folgers
Posted 15 September 2012 - 05:01 PM
The drain hose from your dishwasher is probably connected to your disposal. From there water will naturally drain down into the bottom of your DW unless there is a high loop in the DW drain hose to prevent it. Do this: If there is enough slack in the DW drain hose, gather it up and tie it up in a way so there is a loop in the hose as close as possible to the top of the sink, then re- attach it to the disposal. That way, any water would have to get above the highest point in the loop to get into the DW.
#3 JoeIsuzu
JoeIsuzu
    Yamabushi
  • 78 posts
Posted 15 September 2012 - 05:46 PM
Does that mean "no check valve"? I'm trying to avoid pulling the dishwasher out, if possible.
I've had this dishwasher for a few years, and this just started happening this week. If it's because the hose isn't high enough--wonder why this hasn't happened until now...
In fact, here's a check valve that's supposed to be for this dishwasher...
Thanks.
Jack
Edited by JoeIsuzu, 15 September 2012 - 05:50 PM.
#4 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 15 September 2012 - 06:03 PM
Check Valve (flap) # 5
remove # 3, 1, 7, 8, 6
#5 JoeIsuzu
JoeIsuzu
    Yamabushi
  • 78 posts
Posted 15 September 2012 - 06:06 PM
Ahh, that helps. The photo (in the catalog) did indeed look like a flap. Looks pretty simple, mechanically. ;) I'm assuming it' may not be completelyy water tight, but should certainly prevent major backflow.
Does it sometimes get clogged/blocked OPEN by large food fragments? Or do they just fail?
Thanks.
Jack
#6 RegUS_PatOff
  • 33,588 posts
Posted 15 September 2012 - 06:36 PM
could be ...
