Whirlpool Washer Mod#WTW57ESVWD Agitates while filling with water
3 replies to this topic
#1 deezus
deezus
    Kohai
  • Chief Appliantologist
  • 297 posts
Posted 17 September 2012 - 04:56 PM
Hi,This unit ,when you start any cycle will immediately start agitating. A few seconds later it will start filling with water while agitating. It will drain and spin fine. It is a whirlpool direct drive based but it is newer. I think it is the air switch malfunctioning but im not sure. Any ideas?
#2 sh2sh2
sh2sh2
    Sōhei
  • 207 posts
  • Flavorite Brew:yeunling
Posted 17 September 2012 - 05:17 PM
replace the "load sense switch", its the one with the air hose running to it
#3 RegUS_PatOff
  • 30,192 posts
Posted 17 September 2012 - 05:21 PM
common problem
If switch fails make sure drain hose is up at least 42 inches from the finished floor
and is discharging into an open stand pipe or laundry tub to prevent water from siphoning that can damaging switch.
The manufacturer has replaced part number W10177795
with this item, part number W10292584
Load Sense (LS) Switch
http://www.repaircli...tDetail/1550760
Temperature-switch-W10292584-01266514.jp
#4 deezus
deezus
    Kohai
  • 297 posts
Posted 17 September 2012 - 06:16 PM
Thanks!!
