Maytag washer LAT8240 no agitate
3 replies to this topic
#1 jumptrout
jumptrout
  • 1,192 posts
  • Flavorite Brew:Coors Light
Posted 17 September 2012 - 07:28 PM
Maytag L:AT8240 fills.
Motor start.
Agitator does not.
New belt.
Pump not jammed.
Spins fine.
30-40 seconds into wash cycle squealing starts.
Drive pulley will rotate counter-clockwise.
Spring loaded motor carriage moves OK.
Can the transmission be bad for wash(agitate)cycle and still spin OK?
#2 Scottthewolf
Scottthewolf
    Senpai
  • 1,933 posts
Posted 17 September 2012 - 10:01 PM
Yes, the transmission could be bad in agitate and good in spin. More than likely the transmission is your problem.
Scott Wolf
#3 jumptrout
jumptrout
  • 1,192 posts
Posted 22 October 2012 - 03:51 PM
Want to update this washer repair.
Removed the motor carriage and cleaned and lubed the glides.
Replaced the carriage return springs.
Washer is working correctly.
  • 24,692 posts
Posted 22 October 2012 - 04:45 PM
Domo for the update, jumptrout! For future readers, a motor mounting kit with new glides, lube, and springs is available ==> http://www.repaircli...t/205999/435455
