elceser
Fisher & Paykel WA37T26G Washer - No Power
5 posts in this topic
Machine stopped several times, but restarted when load rebalanced. Now will not power up with front switch, 120VAC at outlet and Control Module input terminals.
Dead machine is 99.999% caused by a dead control board. The most common cause of a dead control board is a pump wet from leaking shorted-out the board. Doesn't have to be a large leak that puddles on the floor, just enough of a drip to get the pump wet. Look under the machine at the pump for evidence of leaking -- rusting, mineral deposits.
Pump does have rusting and mineral deposits.
Resistance is less than an ohm low of spec? Is pump necessarily shot? I am going to remove and inspect.
If board is damaged, anyone have any luck replacing board components? i.e. DigiKey
The pump is a goner. Don't try to save it.
There's a fuse hard-soldered on the board that a few have tried replacing ... but success on that endeavor depends on whether other board components are bad. F&P does not publish components specs so it all hinges on one's facility with electronics.
There apparently has been a large drop in pump quality in recent years. I have a 1999 GWL08 that had a pump replacement (its first repair) at 12 years, which I paid attention and caught the problem before board damage occurred. Also have a 2004 IWL12, also has had no repairs thus far.
All the gwl 11 and 15 units are now coming with a 2.5 amp loblo fuse in the drain pump circuit, which protects the board if the pump goes south. Not sure if the 37's are like that as well.
