Service Manual PSH23SGNABS
2 replies to this topic
#1 herfdog
herfdog
    Ikkō-ikki
  • 54 posts
Posted 19 September 2012 - 02:06 PM
Would you send service manual for GE fridge PSH23SGNABS?
Also any advice as to what may be causing evaporator fan to run sporaticaly and very slow. I can stop it with my finger, feeling like a feather hit it. What voltage should power evaporator fan motor, AC DC? What amount of voltage, 120 volts, 24 volts or? Do you think this would be the fan motor or the control board?
#2 RegUS_PatOff
  • 30,689 posts
Posted 19 September 2012 - 02:49 PM
... what may be causing evaporator fan to run sporaticaly and very slow.
... What voltage should power evaporator fan motor
... would be the fan motor or the control board?
1) bad Fan and / or MotherBoard (a shorted Fan Motor can cause the MotherBoard to fail)
2) 12v DC and HI, Med, LO speed voltage and feedback voltage
3) yes, could be
PSH23SGNABS w/ Inverter Compressor
service manual
http://appliantology...ter-compressor/
Evaporator Fan Motor
http://www.repaircli...tDetail/1550741
Evaporator-Fan-Motor-WR60X10307-01093918
MotherBoard
http://www.repaircli...tDetail/1266021
Main-Control-Board-WR49X10152-00767638.j
#3 herfdog
herfdog
    Ikkō-ikki
  • 54 posts
Posted 19 September 2012 - 05:25 PM
thanks for the help.
