Washer: protecting it from freezing?
washer freeze winterize
5 replies to this topic
#1 Jack Russell Terrier
    Ikkō-ikki
  • 20 posts
  • Flavorite Brew:Allagash White
Posted 20 September 2012 - 09:24 AM
Here is an interesting question: How can you easily freeze-proof a front loading washer? I have a friend with a cabin high (10,000+ feet above seal level), and sometimes it is vacant in the wintertime with no heat and the temperature inside drops below freezing. The house is designed to be easily freeze-proof (mostly by draining water), but how do you do this with a washer?
Of course washers (front loaders) all have a drain tube by the pump and that is easy to empty. But is this enough? LG and other companies don't want to say more, and sometimes will recommend running a cycle with an anti-freeze product, but this is not acceptable.
Open ended question here: What ideas might you have to deal with this problem?
ps Please don't say heat the cabin, because that is not an option!
#2 Scottthewolf
Scottthewolf
    Senpai
  • 1,914 posts
Posted 20 September 2012 - 10:41 AM
Use RV anti freeze. It is perfectly acceptable for use in major appliances, toilets, drain pipes, etc. and it is non toxic. It is pink in color.
Scott Wolf
#3 Jack Russell Terrier
    Ikkō-ikki
  • 20 posts
Posted 20 September 2012 - 10:55 AM
Thanks Wolf! I guess we are aware of this option, but hoping for another. One obvious question --- how susceptible to freezing is a washer if the pump drain hose is emptied? Second question: Is there a model that is designed well for this issue (easy and thorough draining)?
-JRT
#4 Scottthewolf
Scottthewolf
    Senpai
  • 1,914 posts
Posted 20 September 2012 - 10:57 AM
It is not susceptible to freezing in all water has been emptied from the drain hose and the drain pump.
None of the washers are better or worse for draining all the water out.
Scott Wolf
#5 RegUS_PatOff
  • 30,242 posts
Posted 20 September 2012 - 12:00 PM
yes, RV anti-freeze .. pink
although the other antifreeze (green or yellow ethylene glycol) is also orange now.
The RV antifreeze usually comes in clear round jugs that look like windshield washer fluid..
Posted Image Posted Image
$ 1.00 :whistling:
old picture ...
#6 kdog
    RoughShod
  • 7,428 posts
Posted 03 October 2012 - 12:19 AM
You should also disconnect the fill hoses and drain any water from the water valve to prevent any surprises upon startup
