Sign in to follow this
Followers 0
atcherservice
Tool for a Hub Removal /Amana Washer
2 posts in this topic
Greetings,
Have an Amana Washer m#ALW480DAW I have to replace part#R9900457 hub and seal kit. Its been some time since we have done this repair and one of my techs state he insits there is a special tool to remove that hub. I can't recall that tool, any ideas?
Ken
At'Cher Service A/C and Appliance
www.atcherservice.com
Note:
Maytag used at least (2) different transmissions in those Washers
Do not use 21001868 Seal kit on older transmissions not designed to operate at higher torque levels.
The 21001868 Triple Lip Seal and Bearing kit must only be used with the High Torque Dual Drive service transmission.
The 21001867 High Torque transmission will also include a Triple Lip Seal and Bearing for proper matching of parts.
The High Torque transmission will have An “HT” next to the date code for field identification purposes.
here's some more info
http://appliantology.org/files/file/350-maytag-washer-atlantis-triple-lip-seals-info/
Followers 0
