U-Line Undercounter refrig U-CLRC02175S-40 errors
2 replies to this topic
#1 DanInKansas
DanInKansas
    Sōhei
  • 157 posts
  • Flavorite Brew:Blue Moon or Lion Imperial or Shiner Bock
Posted 23 September 2012 - 09:53 PM
Got a no-cool call on this. Plugged it in on arrival and put an amp meter on it... Compressor would pull current for a few minutes and then kick out. Start relay rattled like a maraca; resistance readings on the compressor looked good.
Ordered a new relay, went out and put it on. Compressor went into operation, but then I got a new set of error codes: control board says all three thermisters are open or shorted to ground.
By this point, I had this thing bolted up and back in its cabinet. I know the right thing to do would be to go back, unship it and take resistance readings on the thermisters, but I am having a really hard time believing all three thermisters bought the farm at the same time. I am leaning towards ordering a control board.
Don't know much about U-Lines and what their history is: has anyone else seen simultaneous thermister failure?
#2 RegUS_PatOff
  • 30,299 posts
Posted 23 September 2012 - 11:01 PM
Black Cabinet with Stainless Steel Door
Daily Ice Rate Up to 40 lbs
Stores Up to 15 lbs. of Ice
2.5 Cu. Ft.
Height 34"
Width 24"
Depth 24"
CLRCO2175S-40 $3,789
http://appliantology...service-manual/
2115R
2115WC
2115WCOL
2175/2275DWRR
2175R
2175RF
2175WC
2175WCOL
CLR2160
CLRCO2175
CO2175/CO2275DWR
CO2175F
2175BEV
2275DWRWS
2275DWRWOL
2275ZWC
2275ZWCOL
1115R
1115WC
1175BEV
1175R
1175WC
ADA24R
#3 DanInKansas
DanInKansas
    Sōhei
  • 157 posts
Posted 25 September 2012 - 08:44 AM
I'm not trying to be dense but I'm not sure what you're getting at there. From the service manual: "If a temperature is indicated, the thermistor is not defective." I can adjust the temps on the board. I still have a hard time believing all three thermistors went out at the same time.
That's really my question to the folks here: Has anyone seen that? Would you believe the control board because you've seen that kind of multiple failure before, or would you take it as a sign the control board has gone out?
