Edited by richseattle56, 02 October 2012 - 04:08 PM.
Posted 25 September 2012 - 06:20 PM
Posted 25 September 2012 - 06:32 PM
If the Thermostat is "open" OR the Controller "thinks" the Thermostat is open, the Dryer won't heat.
You would have to test the resistance of the Thermistor (on the Blower Housing).
AND possibly also at the Controller ...
http://www.repaircli...tDetail/1068039
Posted 25 September 2012 - 07:17 PM
Will not heat (motor runs):
• Open heating element.
• Hi-Limit trips easily or is open.
• Regulating thermostat trips easily or is open.
• Membrane switch open.
• Check ThermistorEdited by richseattle56, 25 September 2012 - 07:18 PM.
Posted 25 September 2012 - 09:54 PM
probably one of the Controllers... What and where is the Membrane switch?
Posted 26 September 2012 - 08:12 PM
