Amana AKGD3060SS spark module location?
cooktop gas spark module amana
3 replies to this topic
#1 Brooke Falconer
Brooke Falconer
    Ikkō-ikki
  • Master Appliantologist
  • 40 posts
  • Flavorite Brew:Heif
Posted 25 September 2012 - 10:25 PM
Good Evening Gentlemen (and the too few and far between Women)
I am working on a Amana 4 burner gas cooktop. The left rear and right front burners are not igniting and after switching around the spark ignitors I have deduced that it requires a new spark module (insert comment if you disagree with my diagnosis here :teehee: ) However I am a little unsure of how to get to the spark module. There is a small access plate under the unit (towards the front of the counter) but it doesn't look big enough to get to the spark module if it is even in there. Does anyone have any experience on where the thing is and how to get to it?
Any help is appreciated,
#14 on this diagram
http://www.reliablep...menlarge/71008/
This is the cooktop
http://www.reliablep...ca/models/75097
#2 Scottthewolf
Scottthewolf
    Senpai
  • 1,914 posts
Posted 25 September 2012 - 11:29 PM
Unfortunately, it looks like you have to remove everything on the top of the unit and separate the main top from the bottom of the unit, just like the pain in the butt Jenn-Air cooktops.
Scott Wolf
#3 RegUS_PatOff
  • 30,242 posts
Posted 26 September 2012 - 04:41 AM
from the service manual:
Maintop Disassembly
1. Disconnect power supply and shut off gas supply to cooktop.
2. Support cooktop from below, to prevent damage to ducting.
3. Remove screws securing maintop to burner box.
4. Remove knobs from control panel, by pulling straight upward, and remove glass control panel.
5. Remove screws securing control panel to maintop.
6. Lift maintop up to remove from burner box.
7. Reverse procedure to reassemble, verifying that maintop is correctly placed on the burner box.
NOTE: When placing maintop back onto burner box verify gasket is properly in place.
  • 24,279 posts
Posted 26 September 2012 - 05:39 AM
Part link to the spark module (RepairClinic ships to Canada now with the same one year return policy!) ==> http://www.repaircli...32020101/822400
