Thermador microwave oven MBBS/01
5 replies to this topic
#1 GreenestOne
GreenestOne
    Yamabushi
  • Chief Appliantologist
  • 70 posts
  • Flavorite Brew:java
Posted 27 September 2012 - 01:27 PM
Unit not heating up. Having opened up the cabinet and turning the oven on you could smell the TRANSFORMER overheating.
Replaced the transformer, magnetron, diode, and checked out all the other thermostats and fuse. Tested the capicator and the meter showed
!.07 microfarads(it's value on the label). turned the unit on, and everything was working, but in a few seconds there seemed to be a draw-down of power, the lights stayed on but dimmed, the water in the test cup got hot but it took longer to heat than normal.
Is this a bad capacitor or possibly something else?
#2 GreenestOne
GreenestOne
    Yamabushi
  • 70 posts
Posted 27 September 2012 - 08:46 PM
Anyone got any ideas about this microwave oven situation? Samurai, where are you?
#3 Scottthewolf
Scottthewolf
    Senpai
  • 1,912 posts
Posted 27 September 2012 - 10:23 PM
Maybe a bad control board or bad stirrer motor?
Scott Wolf
#4 Cactus Bob
Cactus Bob
    Kohai
  • 431 posts
Posted 28 September 2012 - 12:16 AM
was the antenna burned or melted on the old magntron ?
If so look inside the the magntrons mounting hole , is the metal it faces melted or distorted , if it's a painted metal , is the paint burned ? (this cannot be fixed so don't even try)
if the metal has ANY damage of any kind , the microwave will never work right and will overheat the magntron
I am also just guessing but you did check the simple stuff , like the cooling fan
SORRY ABOUT THE SPELLING , I FIX GREAT , I DON'T SPELL WELL
  • 24,264 posts
Posted 28 September 2012 - 07:14 AM
What's the current draw on the magnetron? Should see around 11 to 12 A.
#6 NCARepair
NCARepair
    Sōhei
  • 202 posts
Posted 29 September 2012 - 10:48 AM
What is the line voltage under load?
