whirlpool duet bad tub bearing
3 replies to this topic
#1 bmmc
bmmc
    Sōhei
  • Chief Appliantologist
  • 107 posts
Posted 27 September 2012 - 03:39 PM
m#ghw9150pw2 came in shop with bad rear tub bearing(very sloppy) & belt off.never did one of these bearing jobs.two questions,are there any special tools i need to purchase to do the job(so i can figure them in the estimate) & i saw something here about some type of front bearing should be changed out along with the rear.just want to make sure of what i am getting into here.any tips greatly appreciated.
#2 Skiter29
Skiter29
    Kohai
  • 315 posts
Posted 27 September 2012 - 03:54 PM
The bearing is in the rear end of the tub u will need the rear tub and the inner tub, inner tub usally dosnt come out of the rear very costly and you do not need special tools
  • 24,347 posts
Posted 27 September 2012 - 04:15 PM
Rear drum with bearing ==> http://www.repaircli...mber=GHW9150PW2
Inner Tub ==> http://www.repaircli...mber=GHW9150PW2
#4 Scottthewolf
Scottthewolf
    Senpai
  • 1,919 posts
Posted 27 September 2012 - 06:09 PM
Whirlpool has plans to come out with a whole outer tub and the inner wash basket complete with the counterweights, the bearing and seal, and the shaft assembly because technicians have complained that disassembly and reassembly takes too long and that having to order the separate parts rather than a whole assembly takes up too much space in the van.
Scott Wolf
