Need tech sheet for refrigerator: ED5LHAXMB10
1 reply to this topic
#1 GreenestOne
GreenestOne
    Yamabushi
  • Chief Appliantologist
  • 70 posts
  • Flavorite Brew:java
Posted 27 September 2012 - 08:42 PM
Just need a tech sheet for this model. Got to job and the freezer was -22 F. The fridge compartment was 58F.
The two vents from the freezer were full of ice so no air coming through. There is only one themistor in the fridge
in the control console. There are two small boards in the same compartment, but they seemed to be working. That is, when you turn the temp dials for each compartment the digital lights would change , matching the numbers on the control dials. I don't know what resistance the thermistor
should show. I assumed that at that low a temperature reading there was not a problem with the bimetal in the freezer on the evaporator coil.
( If defrost was not working the freezer would be much warmer-they had been noticing the temp in the fridge side high for a few days.)
Your thoughts are welcome.
#2 RegUS_PatOff
  • 30,210 posts
Posted 27 September 2012 - 10:24 PM
Service and Wiring Sheet - 2255774.pdf
link PM'd
