DWSR483EB0WW Need Manual For Re-assembly!
richseattle56
  • Replies 37
    19
  • richseattle56
    19
richseattle56
there is a red wire coming down from control panel and connects to idler switch on the other side of switch it turns to a pink wire
White goes to groung
according to your wiring diagram:
White wire and Brown wire should be Neutral
(would be ground with a 3-wire Dryer Cord)
Door Switch wire should be Brown w/ Yellow stripe
brown to hi-limit thermo
should be Brown from Timer to Hi-Limit, stays Brown, goes to Idler Switch then turns to Pink
That same Brown also goes to one side of Start Switch, then turns to Red to motor
Brown doesn't go to Motor
Was this Dryer working at all when you got it ?
Had it been re-wired by someone ?
richseattle56
It was hook up by my customer and it buzzed as soon as you plugged it in. I changed the wiring around and got it to work and not buzz but the dryer came on as soon as you put it on any cycle I have not been able to get it to come on and run. It buzzes when plug in with every configuration I have tried. He got the part from Sears and the instruction sheet that is the PDF posted on previous page did not come with it. I tried to contact Sears support and they say they dont put the instruction sheet in the box (by poilicy) because it is a liability. So could the customer have burnt up the motor? I have used the wiring colors in the top picture of the PDF but motor still buzzes.
I only have no stiped wires that go to motor the only stripped wire i have is the red w/ black stripe that comes off the black wire connector and goes to door assembly.
Edited by richseattle56
Red w/ Black should go to the Door Light
... got it to work and not buzz but the dryer came on as soon as you put it on any cycle
Start Switch wiring problem ?
OR bad Start Switch ?
should be Brown from Timer to Hi-Limit, stays Brown ... that same Brown also goes to one side of Start Switch,
What color wires are on the Start Switch ...
I can't help you if it was re-wired ..
you (or someone) would first need to follow the wiring diagram and connect everything as original
richseattle56
Red and orange on one post, Brown on the other start switch.
Start switch infinte ohms when off, continuity when turned.
The brown does go to start switch not to the high-limit as stated above. the brown that i have to motor is same wire all the way to start switch
All the wire ties are in place and nothing looks like its been rewired
as shown on the wiring diagram:
Red should go to Motor
richseattle56
post-59945-0-23420700-1349124792_thumb.jI traced the brown wire back still in all the factory wire ties. It goes to the left of of the start switch to the motor. Edited by richseattle56
well, then that's not the correct wiring diagram, or I don't know what else to tell you ...
richseattle56
The red wire from the start switch goes to the signal switch and to the to the idler arm switch. The brown wire goes to the motor and the High limit thermo.post-59945-0-88766600-1349125249_thumb.j
The wiring diagram does not show a signal switch
yes, it's the EOC Signal
(End of Cycle)
don't connect the Black and Purple (Heater) wires, yet
if looking at page 2
. .1 . . . . 3 . . . . 5 . . . . . 7 . . 8
Purple . . Black . . Pink . . . . Yel . Brown
if looking at page 3
. 5 . . 4 . . . . 6 . . . . 1 . . . . 2
Brown . Yel . . . Pink . . Black . Purple
