phydeauxe64
Whirlpool dishwasher mod# DU1010XTXQ2 occaisionally goes into cancel drain.
10 posts in this topic
I've been out on this dishwasher twice now,the first time it had no rinse aid in it I filled it up it worked for 3 washes then started doin it again. Could it be the turbidity sensor or WTF? How do I put this thing in service mode?again Thanks to all who can help me on this one.
Edited by phydeauxe64
Tech Sheet - W10292953.pdf
link PM'd
Ok tried running diagnostic but no codes came up. It only does it on normal wash, the 1 hour wash works ok. When I run it on normal normal wash it runs about 5 mins. then goes into cancel drain and shuts off.
Whirlpool Service Pointer W10402734
Customer Concern: After 10 min of operation the DW coes into cancel drain and stops. This issue can be very sporatic. Tech will find a 6-1 error code recorded in service diagnostics.
Correction: The control will have to be replaced with one that has upgraded software designed to handle abnormal power variations.
2 people like this
ahh, yes ...
W10402734 Final SL English.pdf
Possible Causes:
This issue may be caused by:
• Siphoning through the drain hose
• Severe Sudsing
• Debris in the sump
• Control Board software error may cause a false error code resulting in cycle cancellation.
(This issue is more likely to happen in areas that are susceptible to abnormal power supply variations)
Correction:
If the customer has a cancel drain issue, check the following:
1. Make sure the dishwasher is installed according to installation instructions provided with the unit.
2. Check for water siphoning out through the drain hose.
Insure that the drain hose termination point is above the water level in the tub.
(The drain loop must be attached to the side of the tub and high enough to prevent siphoning.)
3. Check for severe sudsing or a malfunctioning Rinse Aid dispenser.
4. Check for locked rotor in wash pump.
5. Remove any debris in the bottom of the sump/chopper area.
6. Check for water supply and proper water level in the dishwasher.
7. If all the above checks are OK, then the control will need to be replaced with one that has
See chart for part numbers.
1 person likes this
Thanks fellas, it was over sudsing I didn't put any soap in it and it was FULL of suds. We rinsed it out with a water hose and test ran it and it worked ok. As for power fluctuation it was in an area well known for that problem. So maybe with us testing it at the shop and rinsing it out really good, I think we might have it fixed. Thanks for all your input on this, if it still has problems now I know what to look for. I knew I could count on Y'all. :-)
1 person likes this
just a note ...
must use dishwasher detergent
NOT dish soap nor any other soap.
Suds can be removed with using
a cup of vinegar
OR
a cup of vegetable oil
in a wash cycle.
just a note ...
a cup of vinegar
OR
in a wash cycle.
Customer question on this: will her dishwasher cleaner take care of leftover detergent? It is goopy in there.
it should
Too much rinse aid will cause sudsing as well.
1 person likes this
