Sign in to follow this
Followers 0
s4zando
Asko 7005 Dryer Question (Model Year 1998)
11 posts in this topic
I have an Asko 7005 Dryer (circa 1998) - I need to change the belt - no big deal there. In removing the back cover (inner and outer) and the bearing, I noticed that the "small" foam rubber seal that sits on the drive shaft, behind the rear ball bearing and the drum has disintegrated to a mere shadow of its former self.
I can't find that item on the parts list or listed with the bearings.
Anyone know how to get a replacement or figure out the part number? (might as well fix that too as long as I have everything apart!)
Thanks!
Edited by s4zando
Question number two (number one was about a dryer, same age- )...
It's not opreating or starting when set to Program #1 (Prewash). If I turn the dial to Program #2, it works fine. It seems to me that it's probably the timer or timer motor that needs to be replaced - how should I go about verifying this? Or is there something else that I should be looking at?
(OK, yes, the washer is old, but I don't currently have the money to replace it - so let's just fix this thing and limp along as long as we can! (I know some will disagree, but really for the most part, this has been a pretty solid washer - I 've only had one other service issue in its history.))
Thanks!
./s4z
Edited by s4zando
Nope! I think that's the high-heat reset switch cover.
See the attached images - I apologize in advance for the poor photography.
First is the foam rubber "grommet" behind the ball bearing.
Asko 7005 Drum Rear Bearing and Foam Rubber "grommet"
Second is the foam rubber "grommet" with the ball bearing removed.
Asko 7005 Drum Rear Foam Rubber "grommet"
Thanks!
./s4z
bump? :)
bump? :)
I really don't think that foam is necessary. The dryer will be fine without it.
We need the full model number of the washer from the model and serial # tag to help you, not just the number off the control panel.
Don't think thats a foam seal at all - just a buildup of lint and burnt fabric fibres.
Topics merged
1 person likes this
I've never pulled the rear bearing on one of these but that looks more like a felt oil wick to me, (to keep some lube near the bearings - although these appear to bearings that are semi-sealed with metal covers but still a felt wick would let oil gradually release and seep into the bearings).
So I got the belt installed last night and just vacuumed off the area behind the bearing - I think RoughShod was right - lint'ncrap.
Thanks for your help and guidance!
Now that I've reassembled it, I'm just going to patiently wait for the motor to go. <grin>
./s4z
Followers 0
