Asko 7003 Dryer - My Personal Nightmare - Getting Worse - Any thoughts?
4 replies to this topic
#1 genenpet
genenpet
  • 5 posts
  • Flavorite Brew:Full Sail
Posted 30 September 2012 - 02:34 PM
I moved this to a new thread b/c it is no longer a belt replacement issue:
Was here: http://appliantology...lt-replacement/
Essentially, after replacing the belt, and both wheels I had a working dryer yesterday (tumbles, heats, blows, etc).
I noted, however, that the timer/program didn't seem to be running as it dried. I noted to wife not to leave it on until I had time to troubleshoot.
Wife left it on all night - still running when I got up this morning, but no longer any heat. No matter what program I choose - no heat.
So any thoughts on:
1. What I broke that would cause the dry program not to run correctly (not to ever turn off) (I'm guessing thermistor?)
2. What I broke by leaving it on all night that is causing no more heat to come out (heating element?)
I sort of can't bear the thought of taking this thing apart again, but I'm trying to get up the energy to do so.
Well past $250 in parts at this point. Yuck.
Many many thanks in advance.
#2 RegUS_PatOff
  • 30,300 posts
Posted 30 September 2012 - 06:01 PM
Have you re-set your House Circuit Breakers
and measured for 120v and 240v at the Dryer Cord Terminal Strip ?
OR, may have jarred / broken the Heater Element
#3 Scottthewolf
Scottthewolf
    Senpai
  • 1,919 posts
Posted 30 September 2012 - 06:23 PM
Do you not have space for a full size washer and dryer?
Scott Wolf
#4 DanInKansas
DanInKansas
    Sōhei
  • 157 posts
  • Flavorite Brew:Blue Moon or Lion Imperial or Shiner Bock
Posted 30 September 2012 - 08:33 PM
Have you checked the back? Some Asko models have a resettable high limit cutout in the back.
#5 genenpet
genenpet
  • 5 posts
Posted 30 September 2012 - 08:54 PM
Thanks for the replies - I think the critical thing is that it was heating before it ran all night. So I did check the breaker etc, but it's fine and I don't think I damaged the heating element physically during the repair since it was working for awhile.
The high limit cutout will prevent the machine from starting - so it's not the problem.
Any thoughts about what would have caused the dryer to run continuously in the program without ever shutting down?
And yes, I don't have room for a full size...
