Is there a service flash for Kenmore Elite Oasis washer cntrl brd? 110.27062700
2 replies to this topic
#1 phydeauxe64
phydeauxe64
    Yamabushi
  • 81 posts
  • Flavorite Brew:"Double D" Turbo Coffee
Posted 01 October 2012 - 01:01 PM
I was told that there was a recall on the control boards for the Kenmore Elite Oasis washer model#110.27062600 ser#CT17734966 Has anybuddy here herd that? Sumpthin bout the bord bein falty er bad. It keeps flashin F1 I did find a kink in the pressure switch hose as well as some debris in the air dome,cleared both tried unpluggin it for 15mins plugged it in it ran 1 load then went back to F1 tech sheet says replace control board. Thanks fellas fer yer help on thisun...lol
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,463 posts
  • Flavorite Brew:Killians Red
Posted 01 October 2012 - 06:31 PM
No info on recall but yer on the right track...
had one of these that I foolishly diagnosed without checking the pressure hose,
replaced control and still got F1...quickly found the hole that had been rubbed in the hose.
repaired that and returned the old control to the machine and NUTS...still F1.
so the moral of the story...sometimes they have more than one problem :-)
#3 Budget Appliance Repair
  • 3,994 posts
Posted 02 October 2012 - 06:43 AM
It's not a recall just a service bulletin, not under warranty unless within 1st year or extended warranty plan.
F1 is somewhat of a common error on these and most of the time it's a bad control board.
This discussion has a link to the service bulletin regarding the F1 error in serial number range CT01 - CU52.
http://www.applianto...her-11027092602
Edited by Budget Appliance Repair, 02 October 2012 - 06:44 AM.
William Burk (Willie)
Eureka, CA 95501
