Outer Tub Flood Hose Dumps water part# WH41X0369
Model# WDSR2120J5WW
3 replies to this topic
#1 cityboysrus
cityboysrus
    Ikkō-ikki
  • Appliantologist
  • 34 posts
Posted 01 October 2012 - 11:27 PM
Complaint was washer leaking. After initial test of running a little water and spinning/draining it out. I
filled washer to small water level. Once it started agitating I turned off the washer, and reset water
level switch to large it didn't respond. Ok bad switch right. I removed pressure hose from tub quickly
and blew in it. Washer then responded by filling to large level. Once agitation began water started
dumping out of the bottom of the Flood Hose attached to the outer tub. I know the switch needs to be
replaced, but I've never seen this. What would make the flood hose dump water when it's not
overfilling? Or did it overfill the Large Load water level, and during the cycle it realized and started
dumping water? Just curious?
#2 Budget Appliance Repair
  • 4,032 posts
Posted 02 October 2012 - 06:49 AM
You pressure switch is most likely OK. Your most likely cause of the water coming out the overflow tube is a bad brake on the transmission that would require a new transmission to fix.
Can you spin the spin basket by hand when off with the lid up? If yes then you have a bad brake and when it agitates the basket starts spinning causing the water to whirlpool up over the top of the tub or actually out the overflow tube before it can go over the top..
Edited by Budget Appliance Repair, 02 October 2012 - 06:49 AM.
William Burk (Willie)
Eureka, CA 95501
#3 cityboysrus
cityboysrus
    Ikkō-ikki
  • Appliantologist
  • 34 posts
Posted 02 October 2012 - 09:04 AM
Interesting I'll go back later on today to see. :wallbash:
#4 cityboysrus
cityboysrus
    Ikkō-ikki
  • Appliantologist
  • 34 posts
Posted 02 October 2012 - 10:56 PM
Water Level Sw. was the issue. The switch was failing on the small load setting over filling. So when you reset the switch to large, or super it sent the Water to High. I will keep your suggestion in mind for the future. It helped that the customer admitted to switching the water level without turning off the appliance as well.
