amana washer #nav2330aww brake pads
12 replies to this topic
#1 mrfixit3
mrfixit3
    Yamabushi
  • Chief Appliantologist
  • 94 posts
  • Flavorite Brew:TIMMIES
Posted 01 October 2012 - 01:00 PM
service manual .please. thanks
#2 mrfixit3
mrfixit3
    Yamabushi
  • 94 posts
Posted 01 October 2012 - 02:10 PM
hi. i need to replace the break pads. looking for the best way to access them .thanks
#3 RegUS_PatOff
  • 30,295 posts
Posted 01 October 2012 - 02:43 PM
http://appliantology...odels-16022937/
#4 mrfixit3
mrfixit3
    Yamabushi
  • 94 posts
Posted 01 October 2012 - 03:48 PM
got it . thank you.
#5 mrfixit3
mrfixit3
    Yamabushi
  • 94 posts
Posted 02 October 2012 - 07:26 AM
hi. the pads are shot, the drain hose has been squirting water all over the belt and pullies for a while now. i need to change the pads, belt, and drain hose, my question is, there is a fair amount of greese on the helix and brake disk, this is the first amana i've worked on and wouldn't think this is normal, is it? its already going to be around$175 parts and labor . don't want to put the parts in if their are other problems. thanks
#6 kdog
    RoughShod
  • 7,428 posts
Posted 02 October 2012 - 11:20 PM
Time to put that sucker out to pasture - worn brakes and leaky tub seal are uneconomical
#7 mrfixit3
mrfixit3
    Yamabushi
  • 94 posts
Posted 03 October 2012 - 04:37 AM
so ya think the greese is comming from the tub seal kdog? there is no water leaking from there , not yet anyway. there was greese on the outside and inside of helix,and under the brake disk only. no greese where the pads go,or on the top of brake disk. don't mean to be a pain just wanting to make sure. thanks appreciate your help.
#8 kdog
    RoughShod
  • 7,428 posts
Posted 03 October 2012 - 01:39 PM
It is either water seeping through tub seal, or worse, oil leaking from transmission - may not leak fast enough to be visible - I can tell you that repairs on those machines don't have a happy ending
#9 mrfixit3
mrfixit3
    Yamabushi
  • 94 posts
Posted 03 October 2012 - 01:57 PM
thanks k dog. as always appreciate your help. customer is going to buy new.
#10 RegUS_PatOff
  • 30,295 posts
Posted 03 October 2012 - 02:17 PM
.... customer is going to buy new.
maybe check here with model number before buying ..
#11 Scottthewolf
Scottthewolf
    Senpai
  • 1,919 posts
Posted 03 October 2012 - 10:10 PM
Quite frankly, I don't like any of the appliances sold today, they are too loaded with too much junk to fail, just to save energy. Pretty soon they will have 4 or 5 control boards in them, so you will get 4 or 5 error codes. The tech sheets will have 20 pages just to put the machines in a "test" cycle.
Scott Wolf
#12 kdog
    RoughShod
  • 7,428 posts
Posted 03 October 2012 - 10:58 PM
Think I would take alot of them before one of those Amana machines though
#13 Scottthewolf
Scottthewolf
    Senpai
  • 1,919 posts
Posted 03 October 2012 - 11:29 PM
I agree. I blame Maytag for taking the Speed Queen washer and ruining it. The worst thing they did to this machine is taking the metal outer tub, replacing it with a plastic outer tub, totally replacing the triangular tub bearing and replacing it with a one piece triple lip seal and bearing assembly, thinning out the metal on the base and milk stool,and replacing the concrete counterweight with a spring,
Scott Wolf
