Dacor RSD30 high limit reset
7 replies to this topic
#1 scoman
scoman
  • 2 posts
Posted 15 December 2005 - 09:03 AM
We have a Dacor rsd30 dualfuel range and the oven will not heat, the coils remain cold in any baking/broil mode. I have verified power (240) to the range, and all other functions work. I was told it may be the high limit switch, and there is a way to manually reset it. I cannot find any info on the location or on how to reset it, is this something I can access and reset myself?
Thanks in advance for any help.....Scott
  • 24,708 posts
Posted 15 December 2005 - 07:00 PM
It's behind the grill, just above the door. Press the red button the hi-limit to reset it.
And no more cooking with the door open!
#3 scoman
scoman
  • 2 posts
Posted 16 December 2005 - 02:32 AM
Thanks alot, found it and a good fix......
I used to broil that way......learning the hard way
#4 JoeIsuzu
JoeIsuzu
    Yamabushi
  • 70 posts
Posted 01 January 2013 - 11:17 AM
Can someone clarify the location of this switch?  Mine won't heat in any mode since we ran a cleaning cycle.
Thanks.
Jack
#5 RegUS_PatOff
  • 30,694 posts
Posted 01 January 2013 - 11:41 AM
... won't heat in any mode since we ran a cleaning cycle.
:woot:  :nono:
http://www.repaircli...?R=154&N=756372
High-Limit-Thermostat-82987-00624950.jpg    High-Limit-Thermostat-82987-00625050.jpg        High-Limit-Thermostat-82987-00624706.jpg
# 27, right behind the Door Latch / Lock Assembly Motor
#6 JoeIsuzu
JoeIsuzu
    Yamabushi
  • 70 posts
Posted 01 January 2013 - 11:46 AM
I've removed the front cover and I can see the switch assembly. Still looking for the red button.  Too much dust...getting the shop vac out.
Thanks.
Jack
Edited by JoeIsuzu, 01 January 2013 - 11:57 AM.
#7 certified tech group 51
  • 2,043 posts
Posted 01 January 2013 - 12:06 PM
 Try this, get a good flash light, shine it into the ' air cooling grill', around the lock assy........Can you see the 'High limit switch' ????? look good.............If you find it, use a long thin screwdriver push down on the red button.....But first, turn the power 'OFF'...........Then try to reset the thermal fuse...........turn power 'on' and test............ ( one side of the switch is 'hot' all of the time ) .....
#8 JoeIsuzu
JoeIsuzu
    Yamabushi
  • 70 posts
Posted 01 January 2013 - 12:15 PM
Sorry, while you were replying--I was fixing.  I looked up the part in the catalog and got a photo from 3 angles, and then found the button.  Shut off the breaker, pushed the button, turned power back on, and now it LIVES!  Thanks for your help.  This is the WORST appliance I've ever owned.
Jack
