deezus
Electrolux Refrigerator Mod#ei23bc56is3 Icemaker problem
10 posts in this topic
Hi, this refrigerator works fine but the icemaker doesn't. I checked the board in back both fuses ohm out. The icemaker is frozeover and doesn't do anything. This is a different icemaker than i'm used to so I need some help as it has its own evaporator? Thanks.
If the icemaker is frozen around the the icemaker evaparator than the bi-metal or heater element for the ice maker failed. I recently had that situation and replaced both because I was sure which failed. I havent heard from the customer so I think that fix it.
Its actually frozen around the tray where the ice cubes are made. So its basically like a defrost system in a freezer? Is there any chance its the board? I only ask because the icemaker is literally stuck and doesn't move at all.
Didn't you test the heater for continuity? You could also plug it in as well because its 115v. Then I would just need to ohm out bimetal. If bimetal is open then that is probably the issue is what I was thinking. It also has a dedicated board....I think it has a test mode on front panel as well. Also, the fan at the icemaker isn't running either.
Edited by deezus
I didnt test the heater or bi metal because getting to them to test them is a time comsuming job. You have to first melt all the ice and then take apart the ice maker assembly. I didnt want to take it apart twice. The parts are cheap so it made sense to order both and take it apart when I had the parts.
There is about 12 tests that can be performed on the ice maker from the dispenser board on the freezer door. I called Electrolux for help with the tests.
How do you get into test mode? Also, was the fan running on your unit?
242047000.pdf
link PM'd
(to both)
So, if the fan in the icemaker isn't running, the icemaker is froze over would that maybe be a bad board? And how would I test that? I guess what im asking is that how does this icemaker operate normally? Is the fan running all the time? How do you initiate a harvest mode? thanks.
Edited by deezus
