Electrolux Refrigerator Mod#ei23bc56is3 Icemaker problem
9 replies to this topic
#1 deezus
deezus
    Kohai
  • Chief Appliantologist
  • 297 posts
Posted 04 October 2012 - 05:12 PM
Hi, this refrigerator works fine but the icemaker doesn't. I checked the board in back both fuses ohm out. The icemaker is frozeover and doesn't do anything. This is a different icemaker than i'm used to so I need some help as it has its own evaporator? Thanks.
#2 lifierro
lifierro
  • 18 posts
  • Flavorite Brew:Dos Equis
Posted 04 October 2012 - 05:24 PM
If the icemaker is frozen around the the icemaker evaparator than the bi-metal or heater element for the ice maker failed. I recently had that situation and replaced both because I was sure which failed. I havent heard from the customer so I think that fix it.
#3 deezus
deezus
    Kohai
  • 297 posts
Posted 04 October 2012 - 05:27 PM
Its actually frozen around the tray where the ice cubes are made. So its basically like a defrost system in a freezer? Is there any chance its the board? I only ask because the icemaker is literally stuck and doesn't move at all.
#4 deezus
deezus
    Kohai
  • 297 posts
Posted 04 October 2012 - 05:47 PM
Didn't you test the heater for continuity? You could also plug it in as well because its 115v. Then I would just need to ohm out bimetal. If bimetal is open then that is probably the issue is what I was thinking. It also has a dedicated board....I think it has a test mode on front panel as well. Also, the fan at the icemaker isn't running either.
Edited by deezus, 04 October 2012 - 05:59 PM.
#5 lifierro
lifierro
  • 18 posts
Posted 04 October 2012 - 06:56 PM
I didnt test the heater or bi metal because getting to them to test them is a time comsuming job. You have to first melt all the ice and then take apart the ice maker assembly. I didnt want to take it apart twice. The parts are cheap so it made sense to order both and take it apart when I had the parts.
#6 lifierro
lifierro
  • 18 posts
Posted 04 October 2012 - 06:59 PM
There is about 12 tests that can be performed on the ice maker from the dispenser board on the freezer door. I called Electrolux for help with the tests.
#7 deezus
deezus
    Kohai
  • 297 posts
Posted 04 October 2012 - 07:06 PM
How do you get into test mode? Also, was the fan running on your unit?
#8 RegUS_PatOff
  • 30,192 posts
Posted 04 October 2012 - 07:19 PM
242047000.pdf
link PM'd
(to both)
#9 deezus
deezus
    Kohai
  • 297 posts
Posted 04 October 2012 - 10:04 PM
So, if the fan in the icemaker isn't running, the icemaker is froze over would that maybe be a bad board? And how would I test that? I guess what im asking is that how does this icemaker operate normally? Is the fan running all the time? How do you initiate a harvest mode? thanks.
Edited by deezus, 04 October 2012 - 10:12 PM.
#10 RegUS_PatOff
  • 30,192 posts
Posted 05 October 2012 - 12:25 AM
http://appliantology...oor-w-icemaker/
