Kenmore Oasis washer 110.27092601
continually out of balance
11 replies to this topic
#1 herfdog
herfdog
    Ikkō-ikki
  • 54 posts
Posted 04 October 2012 - 05:44 PM
Has anyone ran into this problem before? The washer is level and the suspension is good yet the machine continually faults out of balance with loads of all sizes. When load is rearranged the problem persists. I ran it in service mode with no problems, no stored faults, not unusually wobbly. Any suggestions?
thanks
#2 Scottthewolf
Scottthewolf
    Senpai
  • 1,919 posts
Posted 04 October 2012 - 06:25 PM
You need to replace all 4 of the suspension rods as a kit. Even though they look all right, they aren't.
http://www.repaircli...0189077/1456067
Scott Wolf
#3 herfdog
herfdog
    Ikkō-ikki
  • 54 posts
Posted 04 October 2012 - 06:30 PM
Thanks for the advice.
#4 herfdog
herfdog
    Ikkō-ikki
  • 54 posts
Posted 19 October 2012 - 04:26 PM
Unfortunately, I'm still getting the same fault after replacing suspension kit. Any other ideas?
#5 Scottthewolf
Scottthewolf
    Senpai
  • 1,919 posts
Posted 19 October 2012 - 04:48 PM
The rotor and stator at the very bottom of the machine may have worked it's way loose. Try tightening the large hex screw. As a last resort, they also suggest replacing the electronic control board. The new electronic control is supposed to have upgraded software to be more tolerant with unbalanced loads.
Scott Wolf
#6 NCARepair
NCARepair
    Sōhei
  • 202 posts
Posted 19 October 2012 - 05:26 PM
Replacing the spin basket fixed the one that i had that would go out of balance. This went out of balance empty though.
#7 Scottthewolf
Scottthewolf
    Senpai
  • 1,919 posts
Posted 19 October 2012 - 05:32 PM
I never liked ANY ot the top loading washers that don't have an agitator. They may wash well, but they suck in durability and reliability.The Whirlpool Calypso was a POS, The Cabrio/Oasis is a POS plus. When I worked for Maytag Factory Service we called the Neptune T/L the clothes shredder.
Scott Wolf
#8 sh2sh2
sh2sh2
    Sōhei
  • 213 posts
  • Flavorite Brew:yeunling
Posted 19 October 2012 - 06:29 PM
We call the Neptune T/L the cement mixer
I have seen a loose rotor bolt cause a off balance code and a f51 code many times.
#9 mark mac
mark mac
    Sōhei
  • 190 posts
Posted 19 October 2012 - 08:12 PM
you could have clothes stuck in the bottom of the tub under the basket
#10 jb8103
jb8103
    Kohai
  • Chief Appliantologist
  • 459 posts
  • Flavorite Brew:Ginger ale
Posted 20 October 2012 - 04:38 PM
...not unusually wobbly. Any suggestions?
thanks
Well, if it's faulting out of balance, when it is not observably out of balance, that says software error to me.
'Course, it's almost a reflex for me to suspect the board nowadays.
First, do no harm.
#11 nickfixit
nickfixit
  • 1,965 posts
Posted 21 October 2012 - 07:52 AM
Pull the basket and inspect the main shaft. If it's all rusted or covered with crud, it will cause the basket to hang up when moving up and down between the wash and spin positions. Clean the shaft and the inside of the basket bearing, you may need steel wool or sand paper. Then put a thin coating of grease on both surfaces and re-assemble. Give it a test.
#12 herfdog
herfdog
    Ikkō-ikki
  • 54 posts
Posted 22 October 2012 - 09:08 AM
Thanks to you all. I have a few issues to look at the most likely being it "is a POS". The control electronics sounds possible although I replaced that along with cleaning up the RPS connections for an F-51 fault a little over two years ago.
Kenmore Oasis / Whirlpool Cabrio / Maytag Bravo Washer Continually Goes out of Balance
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 05 October 2012 - 07:42 AM
Has anyone ran into this problem before? The washer is level and the suspension is good yet the machine continually faults out of balance with loads of all sizes. When load is rearranged the problem persists. I ran it in service mode...
Read Full Entry →
