Frost in freezer. Not cold enough. Runs all the time.
Amana BCI20TL-P139702WL
3 replies to this topic
#1 gary
gary
    Yamabushi
  • 60 posts
Posted 04 October 2012 - 07:54 PM
Hi. I'm almost certain I had this issue in the past and received repair guidance here, but a search did not yield my prior inquiry.
Current situation:
Amana Bottom Freezer
Model: BCI20TL-P1309702WL
Lately the ice seems to have a surface layer of liquid water. Son is reporting popsicles don't seem as frozen as usual. Frost is steadily building up on the back panel of the freezer. The unit is running all the time.
From memory, I believe if I pull the back panel off I will find a block of ice. Recollection also says the fix was to replace a relatively small item that I believe is related to the defrost system. I have scanned the repair FAQ and have pretty much verified my recollection.
I'm looking at parts listings for my unit and I'm not seeing, e.g., "defrost timer." I'm sure it's there, I'm just blind. So, to sum up, I'm posting here for hopes of getting at the issue sooner than later. I'm going on travel next week so I only have tomorrow and Saturday to locate a part and fix this so the wife doesn't (potentially) have to operate out of coolers while I'm away.
Is it still customary to open a beer while contemplating a repair? If so, I'll do that now. Thank you.
Gary
Edited by gary, 04 October 2012 - 08:01 PM.
#2 gary
gary
    Yamabushi
  • 60 posts
Posted 04 October 2012 - 07:59 PM
Aha! I suspect the disrespectful part is the thermostat.
PART NUMBER: 10442407
Substitution: 10442411
Thoughts?
Edited by Samurai Appliance Repair Man, 05 October 2012 - 07:41 AM.
#3 RegUS_PatOff
  • 30,269 posts
Posted 04 October 2012 - 09:13 PM
tech sheet
T120_8R1.pdf
link PM'd
could be the Defrost Thermostat again
http://www.repaircli...rtDetail/888801
OR
http://www.repaircli...tDetail/1156627
http://www.repaircli...rtDetail/379148
Defrost-Heater-Assembly-10428409-0063832
#4 gary
gary
    Yamabushi
  • 60 posts
Posted 06 October 2012 - 05:58 PM
Put a new thermostat in today. So far, so good.
Great site.
Good times.
