GSS25SGMB BS Totally Dead except lights
20 replies to this topic
#1 richseattle56
richseattle56
    Kohai
  • Chief Appliantologist
  • 295 posts
  • Flavorite Brew:Coors Light or Vodka
Posted 05 October 2012 - 06:19 PM
No evap. fan, no condensor fan, no compressor. Any sugestions on where to start diagnosing. When first plugged in you can hear the compressor try to start , that is you hear a buzz, and it stops after a second or 3.
The compressor tests out, no open, no short. The relay also has continuity. as does the overload. I think I remember reading somewhere that the Evap. fan, and the condensor fan does not run until the compressor runs for a few minutes.
thanks
Edited by richseattle56, 05 October 2012 - 07:05 PM.
#2 RegUS_PatOff
  • 30,266 posts
Posted 05 October 2012 - 07:13 PM
http://www.repaircli...rtDetail/945622
Main-Control-Board-WR55X10150-00896903.j
http://www.repaircli...tDetail/1531075
Main-Control-Board-WR55X10942-01091474.j
http://www.repaircli...rtDetail/914093
#3 richseattle56
richseattle56
    Kohai
  • 295 posts
Posted 05 October 2012 - 07:26 PM
http://appliantology...ator-diagnosis/
Between J9 and J7 pin 9 I do get 120 Volts,
The compressor trying to start do you think the board is bad?
Also can I check the compessor with a 3in1 isolated outside the unit?
Edited by richseattle56, 05 October 2012 - 07:43 PM.
#4 RegUS_PatOff
  • 30,266 posts
Posted 05 October 2012 - 09:31 PM
... Between J9 and J7 pin 9 I do get 120 Volts,
... The compressor trying to start do you think the board is bad?
... Also can I check the compessor with a 3in1 isolated outside the unit?
1) that's the Defrost heater
2) not mentioned in first posr
3) should be OK to try
http://appliantology...-w-encoder-sxs/
#5 richseattle56
richseattle56
    Kohai
  • 295 posts
Posted 07 October 2012 - 12:36 PM
Compressor runs when I hook a 3 in 1 to it. Page 47 of the manual says "
"Check for 120VAC at connector J7-9
orange wire to TERMINAL-J8 black wire.
Do you have 120VAC? --- No--- Replace main board"
I get zero from those two pins.
So I think its the board.
Here are the resistance values of thermistors @ 56 degrees:
FF1 thermistor= 13.37K ohms
FF2 Thermistor= 6.24K ohms
FZ Thermistor= 6.63K ohhms
Evap. Thermistor= 6.47K ohms
Edited by richseattle56, 07 October 2012 - 01:35 PM.
#6 Cactus Bob
Cactus Bob
    Kohai
  • 431 posts
Posted 07 October 2012 - 12:47 PM
just be carefil before buying a motherboard
you said it first , the compressor trys to start and then kicks off after 3 seconds , if this is true your motherboard has to be good
this leads me to a bad PTC relay or a bad compressor
then you said the compressor runs ok when connected to a 3&1 , so the compressor must be good
so that leads me back to the PTC relay on the compressor
the PTC relay is a cheep gamble , the motherboard is not
Edited by Cactus Bob, 07 October 2012 - 12:48 PM.
SORRY ABOUT THE SPELLING , I FIX GREAT , I DON'T SPELL WELL
#7 RegUS_PatOff
  • 30,266 posts
Posted 07 October 2012 - 01:01 PM
Compressor wouldn't run if there's 0 voltage at J8 pin 1
  • 24,321 posts
Posted 07 October 2012 - 01:16 PM
Compressor start relay ==> http://www.repaircli...7X10025/1063791
and overload ==> http://www.repaircli...08X10026/913170
#9 richseattle56
richseattle56
    Kohai
  • 295 posts
Posted 07 October 2012 - 01:44 PM
The relay and overlaod have continuity. The relay doesnt rattlle when shaken. I do not get 120V AC on any two terminals of the compressor.
Also if I put 120V AC to the two terminals on the start device/relay will compressor start if relay is good?
Edited by richseattle56, 07 October 2012 - 02:42 PM.
#10 Cactus Bob
Cactus Bob
    Kohai
  • 431 posts
Posted 07 October 2012 - 04:01 PM
yes and no ........if you put one wire on the overload , and one wire on the ptc relay , it will start
never put any wires directly on the compressor
the only time you would put both wires on a start device is in case of a whrilpool type starter , in this case one wire is just wired to the overload inside where you cant see it , so it's all the same anyway
#11 richseattle56
richseattle56
    Kohai
  • 295 posts
Posted 07 October 2012 - 04:10 PM
Ok put one wire to overload and one wire to ptc relay from 120V AC test cord, compressor came on and ran.
From all of the above, past posts ect. am leaning towards the main board.
Anyone have any imput?
The main board has been replaced at least once. The board that is in the fridge now is a WR55X10942. Which is the sub for the original baoard. The original board was the WRX5510083
Edited by richseattle56, 07 October 2012 - 08:10 PM.
#12 richseattle56
richseattle56
    Kohai
  • 295 posts
Posted 08 October 2012 - 06:38 PM
Im a little reluctent to replace the board, if I buy it locally I bought it. If I buy it Repair Clinic. I bought it for 3 weeks. HELP
#13 Scottthewolf
Scottthewolf
    Senpai
  • 1,917 posts
Posted 08 October 2012 - 07:09 PM
If you don't want to buy the board, sounds like you want to give up, just like 60 percent of consumers today who just go out and buy new appliances and find out they have more problems with the new appliances.
Scott Wolf
#14 NCARepair
NCARepair
    Sōhei
  • 202 posts
Posted 08 October 2012 - 09:27 PM
Jump the comp and the l1 terminals for the compressor on the main board,largest connector and see if compressor starts. Main board if it does.
#15 richseattle56
richseattle56
    Kohai
  • 295 posts
Posted 09 October 2012 - 06:29 PM
Jump what two terminals on which connector? I need your help.
#16 NCARepair
NCARepair
    Sōhei
  • 202 posts
Posted 09 October 2012 - 08:35 PM
With the control board cover off,looking at the board the connector you want will be on the left. It is the largest one of the two and has three wires on it. The connector may be bluish in color. On the board the wires are labeled L1,comp & def. jump the ones with a wire jumper that say L1 & comp should start comp if comp and relay are good. On regs picture of the board above you can see the lettering on the board,it is under the connector.
#17 Samurai Appliance Repair Man
  • 24,321 posts
Posted 09 October 2012 - 10:25 PM
#18 jb8103
jb8103
    Kohai
  • 457 posts
  • Flavorite Brew:Ginger ale
Posted 09 October 2012 - 11:48 PM
Wow, that is good, Samurai. So Rich would jump J8 to J11, correct? If it starts, the board must have a faulty relay?
Edited by jb8103, 09 October 2012 - 11:48 PM.
First, do no harm.
#19 NCARepair
NCARepair
    Sōhei
  • 202 posts
Posted 10 October 2012 - 12:22 AM
You could also pull the board and check for a blown solder joint. Also jumping J11to J9 will power the defrost heater.
#20 richseattle56
richseattle56
    Kohai
  • 295 posts
Posted 10 October 2012 - 02:21 PM
Jumped Comp. and Line, Compressor ran replaced board all is well.
Thanks to all.
Edited by Samurai Appliance Repair Man, 10 October 2012 - 02:59 PM.
