Whirlpool WTW5505SQ1
75 replies to this topic
#1 pzion
pzion
    Yamabushi
  • 60 posts
Posted 07 October 2012 - 06:51 AM
There's a whirlpool model WTW5505SQ1 for sale that I put a bid of $150 for. Thought to check what you think of this model? Wasn't able to find out if it's a direct drive or not. It's supposedly in "excellent" condition.
Thanks.
Edited by pzion, 07 October 2012 - 06:54 AM.
#2 vee8power
vee8power
    Sōhei
  • 115 posts
  • Flavorite Brew:Folgers
Posted 07 October 2012 - 07:12 AM
That's the good ol' direct drive Whirlpool :thumbsup:
#3 pzion
pzion
    Yamabushi
  • 60 posts
Posted 09 October 2012 - 07:40 PM
We got it (for $200). Would you know what the weight is? I still have to pick it up. Also, is there a repair manual?
Thanks.
#4 vee8power
vee8power
    Sōhei
  • 115 posts
Posted 10 October 2012 - 08:20 AM
That's one of the lightest washing machines around. One man, an appliance dolly, and a truck with a ramp or lift, or two guys to lift it on and off a pickup truck. There's a repair manual for it in the downloads section of this website.
#5 pzion
pzion
    Yamabushi
  • 60 posts
Posted 10 October 2012 - 08:56 AM
Edited by pzion, 11 October 2012 - 08:25 AM.
#6 pzion
pzion
    Yamabushi
  • 60 posts
Posted 11 October 2012 - 08:26 AM
(Don't know if you missed this - I've got the machine sitting on its side in the van and it might not get moved upright for 12 hours or more.)
One other question -- we've got a van and would have to lay the machine on its side. I saw in the manual for a belt drive whirlpool that it said to not let it sit on its side for too long because the oil would drain out of the motor (?). Was wondering if there's any problem with putting this machine on its side?
#7 Budget Appliance Repair
  • 3,999 posts
Posted 12 October 2012 - 06:20 AM
If you must lay it on its side you should clean the top of the transmission cover and put a small strip of packing tape over the small vent hole that is in the middle of the little bump on the top of the transmission cover.
And when you set it back up right make sure the suspension skate plate between the tub and base assembly is in its correct position, (take a look at how it is before laying it on its side and especially before driving with it laying on its side, so you know how it should look when in correct position).
William Burk (Willie)
Eureka, CA 95501
#8 pzion
pzion
    Yamabushi
  • 60 posts
Posted 14 October 2012 - 03:35 PM
We finally got the machine hooked up and did a test run. It makes a loud clanking sound when changing between cycles. I assume it's not supposed to do that.
#9 sh2sh2
sh2sh2
    Sōhei
  • 211 posts
  • Flavorite Brew:yeunling
Posted 14 October 2012 - 05:47 PM
when it goes into spin it will make a loud clunk noise and it shifts into spin
#10 RegUS_PatOff
  • 30,226 posts
Posted 14 October 2012 - 07:32 PM
... and it didn't make that noise, before the move, when you tried the Washer ?
#11 pzion
pzion
    Yamabushi
  • 60 posts
Posted 14 October 2012 - 10:56 PM
Are you saying it's supposed to do that?
#12 RegUS_PatOff
  • 30,226 posts
Posted 14 October 2012 - 11:06 PM
no, but trying to determine if it was due to the tipping and the move,
OR if it got worn-out or was defective before the sale.
Post YouTube video ?
#13 sh2sh2
sh2sh2
    Sōhei
  • 211 posts
Posted 15 October 2012 - 06:51 AM
all the direct drive washers i have ever worked on make a clunk/clank or some sort of noise when going into spin, just one clank not for the hole cycle, just as the gear engages, some are louder then others but i never worry about it, but regus is right and we need to make sure the suspension parts didnt get out of place when you moved it
Edited by sh2sh2, 15 October 2012 - 06:51 AM.
#14 pzion
pzion
    Yamabushi
  • 60 posts
Posted 15 October 2012 - 09:03 AM
I was very careful when moving it and transporting it. I'll try and figure out how to send a video. (Our camera is able to do it but I've never done it before.)
Thanks.
#15 kdog
    RoughShod
  • 7,428 posts
Posted 16 October 2012 - 12:38 AM
A sound recording may suffice, can make those here: http://soundcloud.co...ge-washer-drain
#16 pzion
pzion
    Yamabushi
  • 60 posts
Posted 16 October 2012 - 09:34 AM
Edited by pzion, 16 October 2012 - 09:37 AM.
#17 RegUS_PatOff
  • 30,226 posts
Posted 16 October 2012 - 09:59 AM
hard to tell..
if you could video the Agitator / Tub
(lid Switch by-passed)
#18 pzion
pzion
    Yamabushi
  • 60 posts
Posted 16 October 2012 - 10:25 AM
Did you mean showing the agitation only or agitation to spin? In the video there were no clothes in the washer - just water.
#19 RegUS_PatOff
  • 30,226 posts
Posted 16 October 2012 - 10:27 AM
whatever, whenever the "noise" happens ...
#20 DADoESTX
DADoESTX
    Kohai
  • 260 posts
  • Flavorite Brew:Iced tea with a spike of earl grey
Posted 16 October 2012 - 01:29 PM
Listen closely to the vid starting at about 1:07 ... I hear squeaking noises of spin acceleration/oscillation during what should be a neutral drain period. There's a "clunk" at the start of drain, as if the neutral drain mechanism is slipping directly into spin.
Understanding the Neutral Drain Function in a Whirlpool Direct-Drive Washer Transmission
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 19 October 2012 - 11:50 AM
The neutral drain in the Whirlpool direct-drive washer puts the transmission into neutral while the tub is draining.  The purpose is to save wear and tear on the clutch, drive coupler, and motor.  While it's function and operation are simple and easy to understand, it can still be confusing for folks.
Chief Master Appliantologist DADoESTX...
Read Full Entry →
