Whirlpool WTW5505SQ1
75 replies to this topic
#61 pzion
pzion
    Yamabushi
  • 60 posts
Posted 07 February 2013 - 09:38 AM
Ok - thanks. I got it off and am going to post a video of the open gearbox. I'm wondering how to tell if the neutral drain is working (by watching the open gearbox)?
Edited by pzion, 07 February 2013 - 09:39 AM.
#62 RegUS_PatOff
  • 30,266 posts
Posted 07 February 2013 - 10:07 AM
did you download and read this info ?
some info
http://appliantology...ansmision-info/
#63 fairbank56
fairbank56
    Sōhei
  • 145 posts
Posted 07 February 2013 - 10:21 AM
  Run the input shaft CCW (agitation mode) for a few seconds to set neutral drain, then run it CW for neutral drain. The large spin gear should not be turning during neutral drain. Stop the drill for a few seconds, then start again CW and the large spin gear should now start turning. Iv'e never tested neutral drain this way and it may not work because with the gearcase removed, there is no resistance to the spin gear as there would be with the gearcase installed. The neutral plate rotates in neutral drain and there will be friction between the spin gear cam and the spin gear hub. You could try holding the spin pinion gear to simulate the external resistance.
Eric
Edited by fairbank56, 07 February 2013 - 10:33 AM.
#64 pzion
pzion
    Yamabushi
  • 60 posts
Posted 07 February 2013 - 01:05 PM
I had, but now that I've seen the gearbox open, it's a little easier to understand.
Thanks.
#65 pzion
pzion
    Yamabushi
  • 60 posts
Posted 07 February 2013 - 01:16 PM
Here's the video:
Edited by pzion, 07 February 2013 - 01:31 PM.
#66 fairbank56
fairbank56
    Sōhei
  • 145 posts
Posted 07 February 2013 - 01:59 PM
  After agitate mode, it seems to work in neutral drain for a second or two and then quickly goes into spin and we already know that neutral drain isn't working based on your previous video. I would just install a new neutral drain kit.
Eric
#67 Scottthewolf
Scottthewolf
    Senpai
  • 1,917 posts
Posted 07 February 2013 - 06:01 PM
I've never had a gearcase open ever. I've always replaced complete gearcases. Not worth my time or trouble to repair a gearcase.  Time is money. The more calls I can do, the more money I can make, since we are flat rate. The same goes for restringing dryer elements, I would rather just mark up my parts more than to charge more for labor. We are appliance technicians, not part rebuilders.
Edited by Scottthewolf, 07 February 2013 - 06:03 PM.
Scott Wolf
#68 pzion
pzion
    Yamabushi
  • 60 posts
Posted 08 February 2013 - 11:36 AM
Eric
Maybe there wasn't enough centrifugal force from the drill to keep the latch in position? The video is showing the gearcase with the new parts already installed.
Edited by pzion, 08 February 2013 - 11:40 AM.
#69 fairbank56
fairbank56
    Sōhei
  • 145 posts
Posted 08 February 2013 - 12:37 PM
  That's a good possibility as well as the fact that there is no physical resistance on the spin pinion gear to prevent the spin gear from rotating, as there normally would be during neutral drain. The neutral plate spins all the time and during neutral drain, the latch is engaged with the cam ring which spins on the spin gear hub. There is enough friction there to spin the spin gear if nothing is holding it. That's why I suggested holding the spin pinion gear during the test.
  Actually, now that I remember, it takes 3 rotations of the neutral plate in spin direction before the latch engages for neutral drain and you can sorta see that in the video.
Eric
Edited by fairbank56, 08 February 2013 - 12:44 PM.
#70 nickfixit
nickfixit
  • 1,965 posts
Posted 10 February 2013 - 08:30 AM
Love the video
Edited by nickfixit, 10 February 2013 - 10:55 AM.
#71 pzion
pzion
    Yamabushi
  • 60 posts
Posted 10 February 2013 - 12:05 PM
It seems like the latch is not connecting with the cam to cause it to slip on the hub for pump out. I tried holding the spin gear during the agitate mode and the cam still only slips for about 3 rotations before it catches for the spin.
According to the manual, the latch is supposed to keep the cam slilping until the motor stops.
I wonder if the gear oil is necessary to make the latch swing out.
Edited by pzion, 11 February 2013 - 12:51 AM.
#72 pzion
pzion
    Yamabushi
  • 60 posts
Posted 12 February 2013 - 01:40 AM
Actually, wouldn't the problem be that something is causing the spin pawl to move out and catch one of the bosses on the spin gear?
#73 pzion
pzion
    Yamabushi
  • 60 posts
Posted 07 March 2013 - 12:22 PM
Starting to put it back together. I don't see how to install the shaft seal. This is a picture of the shaft. When I scraped it it looked like metal.
This is a picture of the empty gearcase and cover. (Thought it might be of interest).
Edited by pzion, 07 March 2013 - 12:25 PM.
#74 pzion
pzion
    Yamabushi
  • 60 posts
Posted 15 March 2013 - 12:10 PM
While you have the cover off, replace the cover seal.............P/N 3349985...............and for your added viewing pleasure,  replace the drive shaft seal..P/N 285352......If any oil leaked out, top off with 30 wt. non-detergent motor oil..........Reseal the cover with  a  RTV sealant....or Form-a-Gasket. ( no pressure in the gearbox if the vent is clear )...This machine should give you years of service except for the occasional broken lid switch.........
I'm having trouble getting the cover seal off. It's coming off in pieces and seems to be attached with gasket sealer.
#75 pzion
pzion
    Yamabushi
  • 60 posts
Posted 17 March 2013 - 08:10 AM
Found a way to do it -- I put it on top of a propane burner and when the flames stopped, I saw that what was left of the cover seal had fallen out.
#76 pzion
pzion
    Yamabushi
  • 60 posts
Posted 22 March 2013 - 03:08 PM
Good news -
Someone who has rebuilt these transmissions said that you need the motor torque for the neutral drain to function and that there's not enough in a drill for it. He said that he'd never had a problem after putting in the new neutral drain  parts.
This encouraged me to go ahead even though the old parts didn't look that worn.
I went ahead and put it all back together and it's now neutral draining.
Thanks to everyone for your help.
Understanding the Neutral Drain Function in a Whirlpool Direct-Drive Washer Transmission
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 19 October 2012 - 11:50 AM
The neutral drain in the Whirlpool direct-drive washer puts the transmission into neutral while the tub is draining.  The purpose is to save wear and tear on the clutch, drive coupler, and motor.  While it's function and operation are simple and easy to understand, it can still be confusing for folks.
Chief Master Appliantologist DADoESTX...
Read Full Entry →
