Oasis washer model # 110.27086601
4 replies to this topic
#1 repairguy1
repairguy1
    Ikkō-ikki
  • Chief Appliantologist
  • 41 posts
  • Flavorite Brew:Blue Moon
Posted 08 October 2012 - 08:04 AM
During the "clean washer" cycle, which is the only cycle not working, the timer runs from 60 mins to 57 mins and then jumps to 2 mins and drains water and shuts off. No error codes displayed or in history.
Tub moves freely. Anyone encounter this or have any thoughts on what may be happening?
Any help appreciated.
#2 sh2sh2
sh2sh2
    Sōhei
  • 213 posts
  • Flavorite Brew:yeunling
Posted 08 October 2012 - 04:22 PM
i had this once and this is what i noticed. when the cleaning cycle works properly it fill with some water and then spins the tub to slosh the water around the tub, then it fills to the top and adjatates. On the one that i had that was doing what u described it filled with too much water at first and when it went to spin the tub the basket had already floated up and it spun the impeler. it then went to 2 min, drain the water and shut off. I ordered a main control board but unfoutunetly i did not get the call back so i dont know if it fixed it. Hope it helps
#3 nickfixit
nickfixit
  • 1,965 posts
Posted 11 October 2012 - 05:28 AM
it's a known problem on some models, only a new main control will fix it.
  • 24,352 posts
Posted 11 October 2012 - 05:45 AM
Part link to the main control board ==> http://www.repaircli...0189966/1469076
And how to replace it:
#5 repairguy1
repairguy1
    Ikkō-ikki
  • 41 posts
Posted 16 October 2012 - 07:07 AM
  • thanks for all the help
