GE Arctica SxS error codes.
Started by rudyh, Oct 08 2012 04:20 PM
No replies to this topic
#1
Posted 08 October 2012 - 04:20 PM
I have a GE Arctica SxS reefer, gshf6kgzbcww. It is not cooling the fresh food side-all cold air passages are open, evap. fan is running, defrost system works fine. I ran all steps of the diagnostic. All tests pass except for the first 2 tests.
The first is freezer=0, reefer=2: "temperature control panel to main control board communication" returns: 61 22 instead of P or F.
The second is freezer=0, reefer=3: "temperature control panel to dispenser board communication" returns: 64 6 instead of P or F.
The third is freezer=0, reefer=4 which returns a P.
Is this indicating a failure in the temperature control panel or the main control board?
Please help.
Thank you
Rudy
Please help.
Thank you
Rudy
