110.46462501 duet sport no spin intermittant
4 replies to this topic
#1 telefunkenu47
telefunkenu47
    Kohai
  • 325 posts
Posted 09 October 2012 - 03:38 PM
Hi guys/ I have a duet sport, customers actually, went on a no spin complaint. pulled an f01 code, replaced the ccu as directed. week later, same thing. not throwing codes, walks through diagnostics intermittantly. is there something I'm missing? checked all the usual suspects, pump was recently replaced. Any insight here? I ordered a new mcu but not sure if it will fix. seems a little quirky ramping up in diagnostic mode, sometimes spins sometimes not. cust can get it to spin out after repeated attempts. Any suggestions greatly appreciated. Thanks !
Even root canal is easy...if you're a dentist...
#2 jumptrout
jumptrout
  • 1,192 posts
  • Flavorite Brew:Coors Light
Posted 09 October 2012 - 05:37 PM
I would verify the signal from the door switch.
#3 telefunkenu47
telefunkenu47
    Kohai
  • 325 posts
Posted 09 October 2012 - 10:59 PM
have you seen this on the sport?
#4 telefunkenu47
telefunkenu47
    Kohai
  • 325 posts
Posted 10 October 2012 - 07:49 PM
could the pressure switch be causing the unit to go out on suds? since this washer has no display, there wouldnt be a failure code would there? how would one go about verifying that this is happening?
  • 24,698 posts
Posted 10 October 2012 - 07:56 PM
A slow drain or clogged/flakey pump will cause this error, too.
If you're sure the pump and drain check out good, then replace the CCU ==> http://www.repaircli...er=110.46462501
HINT: In situations like this where an analytical solution is elusive due to shitty information from the manufacturer, I always buy the expensive control board from RepairClinic so I can return it in case I'm wrong.
