LG 30" under counter 0ven
Testing oven relays testing relays
7 replies to this topic
#1 GDunham
GDunham
  • 7 posts
  • Flavorite Brew:MEADE
Posted 10 October 2012 - 02:23 PM
LG (Mod LWS3081ST /00... F9 error, no heating. Have tested all elements and thermostat per tech sheet. All are to specs. Do not know how to test relays for the individual elements. Need to find out if it is the relay board or the system board. Thanks in advance.
#2 GDunham
GDunham
  • 7 posts
Posted 10 October 2012 - 03:32 PM
Scratch that last post. The thermostat is bad (open, no continuity). But on further inspection the plastic has melted at one of the leads on the thermostat. What would cause that? I would still like to know how to check relays as well. Again, thanks in advance.
  • 24,694 posts
Posted 10 October 2012 - 08:01 PM
This thermostat? ==> http://www.repaircli...er=LWS3081ST/00
#4 GDunham
GDunham
  • 7 posts
Posted 10 October 2012 - 08:35 PM
Thats the one. Checked with LG, the thermostat is rated at 25A 180C but the oven has two 20A fuses. I'm thinking the only way to melt the plastic would be excess current or heat. But only one lead shows signs of melting. The lead comes directly from the 20A fuse??? Any ideas? Thanks.
  • 24,694 posts
Posted 10 October 2012 - 08:40 PM
Melted plastic body housings and burnt electrical connections are almost always caused by loose electrical connections. Loose connections make heat. Terminals get loose and sloppy over time and eventually arcing starts occurring. It's the type of stuff that keeps up Master Appliantologists in bidness!
#6 kdog
    RoughShod
  • 7,433 posts
Posted 10 October 2012 - 10:30 PM
Here's some good ones:
http://www.repaircli...A037981/1206527
#7 kdog
    RoughShod
  • 7,433 posts
Posted 10 October 2012 - 10:34 PM
Note that during self clean cycle, surfaces within oven become very hot if built into a tight space - can cause tripping of those as well.
#8 GDunham
GDunham
  • 7 posts
Posted 11 October 2012 - 08:35 AM
To my sometimes lucid host and roughshod, thanks for the insight and links.
