GE built-in fridge ZISW42DXA temperature fluctuations
12 replies to this topic
#1 RedToryTy
RedToryTy
    Senpai
  • Chief Appliantologist
  • PipPipPipPip
  • 809 posts
  • Flavorite Brew:Guinness Stout
Posted 11 October 2012 - 09:16 AM
To the Dojo,
This built-in fluctuates in temperature; by that, the low temperature in the freezer goes higher. So, first it'll be five degrees, then ten degrees, then twenty; but, it'll drop back to hard freeze (i.e. 0-5 F). Condenser's clean, compressor's reading "0" lbs. pressure at the service line, defrost timer crackling but cycling. Any relevant experience?
Thanks in advance,
Tyrus
Mr. Tyrus Lee Smith
Owner-Operator, Smith's Appliance Service
701 Baldwin Falls Road
Baldwin, Georgia 30511-2108
706-778-3411
#2 RegUS_PatOff
  • 30,689 posts
Posted 11 October 2012 - 12:43 PM
... defrost timer crackling but cycling.
Defrost Thermostat stuck closed ?
(Fridge defrosts for the full timer cycle)
Defrost Timer "slipping" ?
(staying in Defrost too long) ?
http://www.repaircli...rtDetail/304873
http://www.repaircli...rtDetail/310900
#3 Cactus Bob
Cactus Bob
    Kohai
  • 431 posts
Posted 11 October 2012 - 01:01 PM
freezer temp go high for how long ?
it's normal for freezer temps to go high when in defrost
does it stay high long enough to defrost the food ?
how about the evap coil , did you put eyeballs on it , look for proper frost pattern or a big ol ice block at the top
evap fan ? did you check the money making Ge fan blade has not slipped on the shaft and is now rubbing on the mounts and turning slow
Edited by Cactus Bob, 11 October 2012 - 01:44 PM.
SORRY ABOUT THE SPELLING , I FIX GREAT , I DON'T SPELL WELL
#4 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 809 posts
Posted 16 October 2012 - 06:09 PM
Cactus,
Temp goes high enough to thaw ice cream and ice in bucket. GE evap fan blade working fine (someone in Louisville just cried). I don't know how to get the cover off the evaporator; do you?
Mr. Tyrus Lee Smith
706-778-3411
  • 24,698 posts
Posted 17 October 2012 - 07:14 AM
How are
How are you collecting these temperature data points? Are you using a temperature data logger or just spot checking? This is an excellent example situation where a temperature data logger can give you a lot more insight into what's happening. For example, can show if it's a regular pattern and, if so, at what intervals which you could then correlate to a particular process in the refrigerator (defrost, compressor run time, etc.) Or if it has no repeating pattern, it may be a door closing issue (user error). These are just examples-- who knows what you'll actually find when you get the actual temperature profile:
Here's the temperature data logger that I use:
http://www.amazon.co...g=mrssamskit-20
and you'll need this software kit to get the data to your Windows PC:
#6 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 809 posts
Posted 17 October 2012 - 11:18 AM
Domo origato, Samurai!
Mr. Tyrus Lee Smith
706-778-3411
#7 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 809 posts
Posted 11 November 2012 - 08:06 PM
Update:
Last Monday, I pulled data from my SUPCO temperature logger, getting wild fluctuations in defrost time: anywhere from a minutes to nearly twenty hours. Replaced my timer, b/c the sealed system works fine (pulling down to five-to-negative ten-range) and the other two defrost components work great. Customer called me yesterday to inform me he had a puddle in the floor. What can be wrong if I've swapped the timer, and the defrost bimetal and element are both good: power surges?
Mr. Tyrus Lee Smith
706-778-3411
#8 RegUS_PatOff
  • 30,689 posts
Posted 11 November 2012 - 08:24 PM
... he had a puddle in the floor.
clogged Defrost Drain ?
  • 24,698 posts
Posted 11 November 2012 - 08:30 PM
Post the graph so we can look at it, too.
Yes.
#10 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 809 posts
Posted 13 November 2012 - 07:50 AM
Though the drain is clogged, the lady of the house (VERY dissatisfied with being sandbagged with this fridge) helped me come to the conclusion we would all be better off if they bought a new fridge. :-( (because I didn't get to repair the problem).
Mr. Tyrus Lee Smith
706-778-3411
  • 24,698 posts
Posted 13 November 2012 - 08:16 AM
Would still like to see that graph... it may indicate a sealed system problem such as a periodic ice plug formation in the capillary tube. Having the graph to help confirm this would have enabled you to get the jump on her conclusion to buy a new refrigerator by making that recommendation yourself and thus retaining your place as the expert appliantologist in her eyes.
#12 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 809 posts
Posted 14 November 2012 - 09:32 AM
Many apologies, Samurai. I didn't have my flash drive to transfer the graph files from the XP to the Windows7 computer.
Mr. Tyrus Lee Smith
706-778-3411
  • 24,698 posts
Posted 14 November 2012 - 07:01 PM
Ain't no thang, we'll catch the next one. :beatnik:
