Maytag French Door Refrigerator MFI2568AEW0 No Code
3 replies to this topic
#1 vee8power
vee8power
    Sōhei
  • 118 posts
  • Flavorite Brew:Folgers
Posted 12 October 2012 - 12:12 PM
Looking at this unit, I need to replace the main power board:
http://www.repaircli...2920710/1206507
Problem is, the programming code is torn off the sticker. The serial# is 10928018GX.
Is the code is located somewhere else? Does anyone know a code that will work? Can the code be determined some other way, perhaps from the serial#?
The display board is unresponsive. I found a document that describes how to fix the board, but I would rather replace than stand behind a repair that I've not done before.
#2 Scottthewolf
Scottthewolf
    Senpai
  • 1,914 posts
Posted 12 October 2012 - 10:43 PM
I just checked all my invoices for the same model # to see if I was smart enough to write the code on the invoice and I didn't. Best thing to do is call Maytag directly, give them your model # and serial number and they should be able to help you.
Scott Wolf
#3 vee8power
vee8power
    Sōhei
  • 118 posts
Posted 13 October 2012 - 07:22 AM
Thanks Scott! I called Maytag customer support and they transferred me to Whirlpool in Tennessee. They wouldn't give me any info. citing "liability issues"
#4 Scottthewolf
Scottthewolf
    Senpai
  • 1,914 posts
Posted 13 October 2012 - 11:10 AM
That's total BS, looks like you are going to be stuck calling an authorized servicer and he will have to call the tech help line just to get the programming code for the control board.
Scott Wolf
