Asko 1385 Dishwasher doesn't fill
4 replies to this topic
#1 momfxit
momfxit
    Ikkō-ikki
  • 30 posts
Posted 13 October 2012 - 07:24 PM
My asko will run through the cycles, but will not fill with water. I checked the water inlet valve and it tested at 240.
I'm open to suggestions...I'm not a bright service tech, the husband wants the washer working so any help is greatly appreciated.
Mom
  • 24,218 posts
Posted 13 October 2012 - 07:30 PM
If you're getting 240vac the valve (assume you are in Australia or Europe), and the valve isn't opening, then it's a bad valve by definition
http://www.repaircli...odelNumber=1385
OTOH, if you're located in Ameedika or Oh, Canada and you have 240vac at the valve, then we need to talk 'cuz you should only have 120vac.
Or, are you saying the valve tested at 240 ohms? Without any units with the numbers, I can only guess about what you're talking about. If you did an ohms test o the valve, then you need to check the voltage to it. Something can check good ohms and still be bad. But if it's bad under load (voltage), then it's really bad.
#3 momfxit
momfxit
    Ikkō-ikki
  • 30 posts
Posted 14 October 2012 - 08:51 AM
It test 120 ohms on the meter is USA. It could be a bad valve.
  • 24,218 posts
Posted 14 October 2012 - 01:25 PM
Set your meter to volts and see if the valve is getting 120vac when it should be letting water into the dishwasher. If you're getting 120vac and no water, then replace the valve.
#5 momfxit
momfxit
    Ikkō-ikki
  • 30 posts
Posted 14 October 2012 - 01:53 PM
okay, how would i do that?
