ASKO W600 Washing Machine - Door Latch Broken
#1
Posted 18 October 2012 - 11:45 AM
#2
Posted 18 October 2012 - 11:57 AM
ASKO Service book 600 email me and I will send the file it was too big to upload here-Ken
kjagmin@hotmail.com
#3
Posted 18 October 2012 - 12:26 PM
- kdog likes this
#4
Posted 22 October 2012 - 10:03 AM
1) Broken door latch problem. The door is replaced (the full door assembly). Door fits and works fine. Ran a cycle. No leaks from door but...
2) the long standing problem of water leaking from the bottom of the washer is significantly worse and now the tub does not rotate. My guess is that there is not enough remaining water to trigger the drum to rotate. After watching (and listening to an entire wash cycle) there were no error codes but the tub never rotated and when the cycle ended, the door did not release.
3) Door locking sensor may also need replacing. I anticipated that and ordered the part when I ordered the door since even before the final latch break, the door would periodically not release without using the emergency plastic manual release in the lower front pump area.
4) Even though I routinely clean the pump trap, the heaviest leaking is coming from around that area of the bottom front of the machine. Without the manual, I only removed the top cover and from what I could see no hoses were questionable looking but I will know more once I can get a look at the bottom of the washer.
From the top view (will upload picture tomorrow), the ASKO W600 was amazingly clean and didn't look like a 13 year old machine. Wow..... those Swedish folks were way ahead of the curve on front loader design and assembly. As much as I try to buy American, quality matters and there were few choices available in 1998 when we were looking into high efficiency washers and dryers.
Working my real (read: paying) job today but will resume my appliance work tomorrow after looking over the manual. Thanks all. -Judy
PS. With a listed capacity of 1.9, this size has worked well for two people. I even wash our queen size comforter in it.
With houseguests now, recent levels of laundry meant more items were stuffed into the washer.... which may have aggravated our long standing (and ignored by me) water leaks from the base of the washer into the (no longer ignorable) current water leaking crisis.... where almost all of it runs out soon after the water is pumped in. Yikes.....
Edited by snelljm, 22 October 2012 - 10:21 AM.
#5
Posted 12 November 2012 - 04:26 PM
Original Problem: plastic latch broken on front door panel and dramatic increase in water leaking from bottom of machine.
1) Problem with broken door latch is fixed.
2) Lock Switch. Not knowing if it needs replacing (but ordering the part anyway) I have not attempted to replace door lock switch. [Repair Clinic part number Item # 764056 Manufacturer Number 8061679
3) Water leak source. Tested washer with top and front panel removed. Found two sources of water leaking from the pump hose [Repair Clinic part number Item # 764058 Manufacturer Number 8061681]
At this point, I stopped to wait until the technical manual could be obtained before any more dis-assembly. [actually, I was busy with auto dramas at our house] Meanwhile it was necessary to clean all the debris and disgusting stuff inside the base of the machine from months of water leaking.
Now I am preparing to order the pump hose and wonder if anyone has done this before? Any advice?
All the other hoses seem fine and considering the age of this machine (1998) it is remarkable how sturdy and reliable everything else seems as I looked inside. Pictures will be uploaded once I remember how to do that from home. So that's where I am until this weekend. [Have to pay attention to my paying job first] -Judy
#6
Posted 19 November 2012 - 02:50 PM
#7
Posted 20 November 2012 - 06:48 AM
Also tagged with one or more of these keywords: asko, washing, door broken, technical manual
