#1
Posted 18 October 2012 - 11:49 AM
#2
Posted 18 October 2012 - 01:47 PM
Le Chien Rouge
#3
Posted 18 October 2012 - 02:31 PM
just like analog meters ..- good old dial guages are just fine
sometimes nice to have to see surges, etc.. and to see micro switch transitions ..
- kdog likes this
#5
Posted 18 October 2012 - 03:28 PM
- kdog likes this
#6
Posted 19 October 2012 - 10:58 AM
#7
Posted 19 October 2012 - 01:51 PM
ThanksKen
- tommytech likes this
#8
Posted 21 October 2012 - 08:25 AM
#9
Posted 22 October 2012 - 06:04 PM
I am 'suspect' of any tec that needs electronic gauges to do his work
Yep. This type of thing allows companies to hire PCM's at a low pay rate without the embarrassment involved when its discovered they don't know wtf they are doing. Training the person correctly takes a lot time and $$ and the investment ultimately goes to the person, then they can do with it what they want (like ask for a raise or go to a different company.) On the other hand, minimal training and advanced tools that do the thinking limit the problems in the field, keeps the tech under wraps, and with a smaller investment in the tech.
I know this does not apply universally, don't get in a knot
Edited by Bullstok, 22 October 2012 - 06:27 PM.
#10
Posted 24 October 2012 - 11:27 AM
#11
Posted 26 October 2012 - 08:20 PM
#12
Posted 26 October 2012 - 08:26 PM
Example: it require One British thermal Unit (BTU) to cause One Pound of Water to change One Degree Farenheit, so long as it is between 32 and 212 degrees, at that point - 970 BTU's must be added/subtracted to cause the Water (Stem/Ice) to change One Degree Farenheit.
If you were looking at the pressure at these points, you could measure the tubing etc with a thermometer to calculate the difference.
the Term is applied to locations within the system where you want to guarantee the substance is complete gas or liquid. (Evaporator inlet/outlet, Condenser outlet etc)
Le Chien Rouge
#13
Posted 30 October 2012 - 10:47 AM
#14
Posted 30 October 2012 - 04:01 PM
#15
Posted 30 October 2012 - 06:47 PM
- suampman likes this
Le Chien Rouge
