Frigidaire Model LEH1642DS0 Over/Under Washer /Drier Combo
Guest RJ Kanary_old
Guest RJ Kanary_old
This is a over-under combo model....The drier is squeaking up a storm and
driving me nuts...Can't figure how to get the front off so I can remove what
ever is stuck between the drum and frame.
Marshmallows make poor ear protectors.
