Frigidaire Gallery FSE447GHS0 will not start
3 replies to this topic
#1 bpickett
bpickett
  • 13 posts
  • Flavorite Brew:Great Divide Titan IPA
Posted 22 October 2012 - 01:59 PM
Just replaced motor, door switch and timer in August and the dryer has worked great until today when it stopped working midway through a cycle. It will not restart. Checked for loose connections that may have worked loose from my earlier repair and all connections seem to be intact. Any help is greatly appreciated.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 22 October 2012 - 02:12 PM
how's the Thermal Limiter # 36 ?
and check & CLEAN the Vent
http://www.repaircli...tDetail/1489053
#3 bpickett
bpickett
  • 13 posts
Posted 24 October 2012 - 10:47 AM
That was it!!! Replaced bad fuse and everything is running fine. Still concerned over what caused it to overheat in the first place. Vents were cleaned two months ago when motor was installed so that isn't the problem this time. BTW, one of the wire leads on the fuse was slightly charred???????
Thanks for your help.
Sorry for the slow response. I had forgotten to mark the topic so that I would get an email notification when someone responded.
#4 RegUS_PatOff
  • 33,588 posts
Posted 24 October 2012 - 11:26 AM
... one of the wire leads on the fuse was slightly charred ????
a loose / dirty / bad connection can over-heat and will char the Terminal and Wire
If not repaired / replaced, may blow the Fuse again
also:
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
$ 4.99 sometimes on sale for $ 2.99
