LG Dishwasher
3 replies to this topic
#1 Skiter29
Skiter29
    Kohai
  • 374 posts
Posted 25 October 2012 - 12:54 PM
Working on a LG Dishwasher Model#LDF6920BB it is leaking down the vent cant see why it is but it is leaking into it and it runs down the vent to the outlet to the floor is this as simple as replacing the vent fan assembly becasue its not leaking around it it is leaking into it then down dont work on to many LG dishwasher any insight would be greatly apprcated thanks in advacne
#2 Chat_in_FL
Chat_in_FL
    Havoc
  • 1,580 posts
  • Flavorite Brew:What's on tap?
Posted 25 October 2012 - 04:12 PM
Had the same issue, ordered the "casing assy," (Vent fan assy). Haven't been back yet to see if that solved the issue.
Mother Teresa
The views and opinions expressed in this post are those of the author and do not necessarily reflect nor represent the views and opinions held by my employer. All data and information provided is for informational purposes only.
Big Brother
#3 Skiter29
Skiter29
    Kohai
  • 374 posts
Posted 25 October 2012 - 04:35 PM
thanks for the answer will order the vent fan assembly
#4 john63
john63
    Dean of LG Appliantology
  • 2,228 posts
Posted 25 October 2012 - 05:54 PM
<<<it runs down the vent to the outlet to the floor>>>
If the "leak" from the vent is more than just a few droplets of water---the BLOWER HOUSING (AKA: Casing Assy)---should be replaced (MJZ61841503).
If the SERIAL NUMBER falls within-----> 712xxx to 812xxx...
The DUCT should be replaced to prevent *droplets* of water from leaking onto the floor (especially wood floors).
The re-designed DUCT has a ninety-degree turn at the outlet to "capture" moisture that can fall from the BLOWER HOUSING.
DUCT: MJZ61841503
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
