Patching Hole In D.W. Tub?
7 replies to this topic
#1 AlexM
AlexM
    Kohai
  • Chief Appliantologist
  • 379 posts
  • Flavorite Brew:Root Beer
Posted 25 October 2012 - 07:29 PM
Dishwasher with hole in tub. A knife or utensil went throught the silverware basket, touched the heating element and melted a hole in the bottom/side of the tub, has anyone successfully patched a D.W. tub? If so, how?
#2 Scottthewolf
Scottthewolf
    Senpai
  • 3,000 posts
Posted 25 October 2012 - 08:01 PM
What brand and model number???
Scott Wolf
#3 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 25 October 2012 - 09:04 PM
#4 AlexM
AlexM
    Kohai
  • 379 posts
Posted 25 October 2012 - 09:11 PM
The Beatles, nicely done, very enjoyable!
G.E. #PDW7380N10SS
#5 Strathy
Strathy
    Head Wrench
  • PipPipPipPip
  • 765 posts
  • Flavorite Brew:Coffee
I used 3M 5200 Marine epoxy on a shattered plastic washer tank about 5 yrs ago ... still going strong. Also used it below the waterline a number of times on my boat and it's still floating. Not sure how it would do with the heating and cooling in a DW, but seems to be OK with the hot water in a washer, so I suppose it should last. If the hole is really big, tape a piece of plastic or something to the underside and then apply from the top. That will give it something solid to set up on. Allow to cure for 5 days ... 7 is better (experience speaking here. lol.)
Neighbour's Appliance Service
Servicing Southern Manitoba, Canada
#6 suampman
suampman
    Kohai
  • Chief+ Appliantologist
  • 307 posts
  • Flavorite Brew:redbridge
Posted 25 October 2012 - 09:23 PM
If the hole is not to big, It can be welded. I have used a soldering iron to weld cracks in plastic. There is plastic welding kits with filler rods. It takes a little practice but can do fine job. Good luck.
#7 AlexM
AlexM
    Kohai
  • 379 posts
Posted 25 October 2012 - 10:08 PM
Both are excellent suggestions...how hot does a heating element get in a D.W. anyway?
#8 Strathy
Strathy
    Head Wrench
  • PipPipPipPip
  • 765 posts
Posted 25 October 2012 - 10:14 PM
The water usually reaches somewhere between 120 and 140 deg. After that the element will be cut out by a thermister or thermostat. There are some 'sani' cycles that attempt to get hotter, but I've seen few that got much over 150. There is a water buffer between the element and the tank, so I think the water temp is more important thing to know.
