Maytag FAV6800AWW stopping at 31 min
9 replies to this topic
#1 aasnowskate
aasnowskate
    Ikkō-ikki
  • Chief Appliantologist
  • 27 posts
  • Flavorite Brew:pabst
Posted 26 October 2012 - 01:46 PM
Had a customer call to say her Maytag Neptune is stopping at 31 minutes into the cycle. It does not go any further than that. She has unplugged the machine, starts the cycle back up and has the same problem. I Haven't been there to check it out yet. Just seeing if anyone has had this problem. She did not say if there was and error code.
#2 Scottthewolf
Scottthewolf
    Senpai
  • 1,933 posts
Posted 26 October 2012 - 02:00 PM
Sounds like the cold water fill is not working or the drain pump isn't working to drain the water out of the machine. You need to find out if there is a fault code.
Scott Wolf
  • 24,720 posts
Posted 26 October 2012 - 02:27 PM
Rinse is done with cold water and that's about the time in the cycle for it. If the cold water flow is restricted, replace the water inlet valve ==> http://www.repaircli...mber=FAV6800AWW
In case it turns out to be the drain pump as Scottthewolf suggested, here's the part link for that ==> http://www.repaircli...mber=FAV6800AWW
#4 aasnowskate
aasnowskate
    Ikkō-ikki
  • 27 posts
Posted 31 October 2012 - 07:27 AM
Thanks for the reply. We can't get out to the customer until friday. Big storm here in Pennsylvania.
She claims there is no falt code. I figured it is the pump, but I will check the inlet valve and let you know.
Thanks for the replies. I'll know what is up on Friday.
#5 aasnowskate
aasnowskate
    Ikkō-ikki
  • 27 posts
Posted 03 November 2012 - 06:04 PM
Went and checked out the washer. I found a dime in the pump. Didn't see it until I wrung out the towel though. That was the first time I worked on the Neptune with the two discs at the bottom of the tub. If someone try to sell me a washer with two discs at the bottom of the tub I would laugh in their face.
Hopefully that engineer went onto better things.
#6 RegUS_PatOff
  • 30,703 posts
Posted 03 November 2012 - 06:26 PM
... Neptune with the two discs at the bottom of the tub.
... try to sell me a washer with two discs at the bottom of the tub I would laugh in their face.
#7 nickfixit
nickfixit
  • 1,990 posts
  • Flavorite Brew:Glen Livit
Posted 09 November 2012 - 07:14 PM
I've worked on at least 100 of these stinkers, and words can not express how much I hate them. I can fix them, but I hate them so bad I feel bad when I fix one. I'm glad the parts are getting expensive, more people junk them, and that makes me feel a little better.
Nick
#8 kdog
    RoughShod
  • 7,433 posts
Posted 09 November 2012 - 09:01 PM
And when that doesn't work:
Attached File  lens19598791_1341603842_a_a___.jpg   13.64KB   3 downloads
#9 sh2sh2
sh2sh2
    Sōhei
  • 227 posts
  • Flavorite Brew:yeunling
Posted 10 November 2012 - 07:47 AM
I am happy every time i condem a neptune TL(cement mixer) or a calypso.
#10 telefunkenu47
telefunkenu47
    Kohai
  • 325 posts
Posted 10 November 2012 - 11:28 PM
N ot
E nough
P arts
T o I think the name says it all
U ndo
N egative
E ngineering
Even root canal is easy...if you're a dentist...
