wall oven K/A KEBS107SSSOO
No replies to this topic
#1 certified tech group 51
  • 2,688 posts
Posted 26 October 2012 - 10:46 PM
Just replaced the thermal fuse P/N 8304452 for the second time in 90 days...... Customer said it only made it 1/2 way thru the clean cycle before she noticed the there was not any heat coming for the front of the wall oven.......Blower is at the high speed for the clean cycle, slow for 'bake'.......She said no problems when she bakes, Correct temps......so it appears the oven sensor is O.K..............Any "service flash " from W/P on this unit???? ...............Cannot tell the customer to not use the clean cycle.. :down: ........Unit has a hidden bake element and the fuse is in the air flow on a small tab in the left corner, half the way up from the bottom, ......Blower pulls the air from under the unit , up the rear corners and then pushes the air under the main control board on top and out the front grill over the door.......Most fuses I have seen are attached to the outer liner, but this is in the air flow......Could be a faulty first fuse but the customer does not like to pay the labor costs....... :sweat: .
