cap tube cutter
3 replies to this topic
#1 tommytech
tommytech
    Sōhei
  • Master Appliantologist
  • 167 posts
  • Flavorite Brew:guiness
Posted 27 October 2012 - 12:45 PM
looking for one of those scissor type tools for cutting cap tubes in reefer systems
#2 Cactus Bob
Cactus Bob
    Kohai
  • 431 posts
Posted 27 October 2012 - 01:25 PM
small file to score the pipe , and bend to snap
works 100%of the time
with 0% failure rate
why pay more ?
SORRY ABOUT THE SPELLING , I FIX GREAT , I DON'T SPELL WELL
#3 certified tech group 51
  • 2,045 posts
Posted 27 October 2012 - 08:11 PM
For a cap tube cutter, ( I know a three sided file is what they say ) But, I use a pair of wire strippers......You find the diameter just over the the size of your cap. tube ........Lightly, score with half of a rotation on the tube, ( scores 360 degs. around ) .......clean break every time........................Just leave the first 3/4 of an inch unsanded and no flux............. less chance of solder moving past the unsanded part to plug the cap. tube.............
#4 nickfixit
nickfixit
  • 1,990 posts
  • Flavorite Brew:Glen Livit
Posted 02 November 2012 - 05:39 PM
Try the old trick of rubbing your fingers behind your ear then rub them on end of the cap tube. The skin oil will foul the end of the tube so no solder will stick or plug the end of the tube.
I use a 3 sided file to cut the cap tube.
Edited by nickfixit, 02 November 2012 - 05:41 PM.
