samsung dishwasher dmt300rfw/xaa
11 replies to this topic
#1 vunger1
vunger1
    Yamabushi
  • Chief Appliantologist
  • 76 posts
  • Flavorite Brew:maxwell house regular blend
Posted 29 October 2012 - 06:59 AM
Dishwasher starts cycle fine, for about 2 min.,then ends cycle goes into a drain mode
(2) then the heavy and quick light began flashing....(over level water error)
Could this error be due to an obstruction in the food chopper area or in the drain line? Causing a slow drain which in turn may leave too much water in the machine for the computer to advance through the cycle?
Any thoughts greatly appreciated
Oh yes customer added that this unit is about 3 weeks old and that it worked flawlessly for the first two weeks.
#2 RegUS_PatOff
  • 30,237 posts
Posted 29 October 2012 - 07:10 AM
Is the Dishwasher empty of water before they start a new Cycle ?
When it starts the Drain Cycle, does the water actually drain OK (completely) ?
#3 vunger1
vunger1
    Yamabushi
  • 76 posts
Posted 29 October 2012 - 11:48 AM
water drains enough that it cant be seen just by opening the door and looking in, however im wondering if there may be water up to just below the filter that cant be seen without going further in.
I was on a warranty call for Assurant Solutions, so i only wanted to do the minimum required ,as they do not pay for xtra labor above and beyond their diagnostics.This was my first service call for them and i was trying to feel them out to see if they were trying to be fair with their servicers or not.They pay the same for 1 trip out or for 4.(Calls are based on triage)Their theory is that 75-80% of calls only require 1 trip so in the long run the servicer comes out ahead,this has not been my experiance.So i told the customer I would get the dishwasher fixed for them even if Samsung and Assurant didnt pay.But on my next trip i would like to be well prepared.
#4 vunger1
vunger1
    Yamabushi
  • 76 posts
Posted 30 October 2012 - 12:54 PM
anyone know what might cause this error
#5 vunger1
vunger1
    Yamabushi
  • 76 posts
Posted 30 October 2012 - 05:44 PM
pleasa somebody a pleasa donta nobody hava da problema widda da dishawasha lika mina eh?
#6 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 691 posts
Posted 30 October 2012 - 06:55 PM
Suspect a stuck water valve, faulty flow meter or possible drain issue. Thats all I got, sorry
#7 Chat_in_FL
Chat_in_FL
    Senpai
  • PipPipPipPip
  • 897 posts
  • Flavorite Brew:Variety is the spice of life!
Posted 31 October 2012 - 04:53 AM
DD97-00131A
http://www.repaircli...700131A/2020870
Classic symptom of Gookus in the Sensor level assy and/or the sensor hose...
Edited by Chat_in_RI, 31 October 2012 - 04:54 AM.
Mother Teresa
#8 vunger1
vunger1
    Yamabushi
  • 76 posts
Posted 31 October 2012 - 04:14 PM
DD97-00131A
Exactly what samsung tech said ,will check that out,Thanks
#9 vunger1
vunger1
    Yamabushi
  • 76 posts
Posted 12 December 2012 - 02:16 PM
Problem solved ,replaced water  fill  level sensor. Thanks for the input.
Water-Fill-Sensor-DD97-00131A--01433606.
Edited by Samurai Appliance Repair Man, 13 December 2012 - 05:23 AM.
Added part link.
#10 certified tech group 51
  • 1,977 posts
Posted 13 December 2012 - 10:10 AM
Do not know how many techs. carry this part on their service vehicles, ( I don't ). So this is a two trip minimum service call............Finish the service call in 1 trip ?????? :deal: .............I  work on all brands...I would need a 27 foot trailer to work for this company.. :no:.........................P.S.   Who pays/ purchases the part???  I had one warranty place call, They said  they will pay $ 125 and they will provide the part.........No way , Jose'......Part mark-up part of the business.....
  • 24,276 posts
Posted 13 December 2012 - 11:45 AM
Yes, two-trip service call and quote the repair fee accordingly. :)
#12 Scottthewolf
Scottthewolf
    Senpai
  • 1,914 posts
Posted 13 December 2012 - 11:02 PM
N.E.W.  is famous for supplying their own parts. They are ridiculously cheap when it comes to purchasing parts.  I went on a call on a Whirlpool electric range, it needed an infinite switch. I asked for the OEM Whirlpool switch because the wiring was a quick disconnect, rather than wire for wire,  they sent me a Robertshaw universal infinite switch. I was PISSED because now I had to take the wires out of the quick disconnect and  reroute the wires because the terminals were not in the same locations!  So first they only pay for 1 service call, and NOW you are going to waste my time because now I have to retrofit the part because you are cheap?  I DON'T THINK SO!
Scott Wolf
