GE Profile TFX25PRYD BB
11 replies to this topic
#1 clancy
clancy
    Ikkō-ikki
  • 20 posts
Posted 30 October 2012 - 10:11 PM
Small amount of Ice Produced no water in door.
I have water at bottom of door there is a connection there I broke the connection and water is there.
Help me please and thank you.
#2 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 30 October 2012 - 11:37 PM
Some insight here: http://appliantology...er-freezing-up/
and here: http://fixitnow.com/...e-refrigerator/
#3 clancy
clancy
    Ikkō-ikki
  • 20 posts
Posted 31 October 2012 - 07:21 AM
Thanks for the links I am thinking that this is not likely the problem as The unit was shut off and not even cold and I can not get water from the dispenser.
#4 certified tech group 51
  • 2,721 posts
Posted 31 October 2012 - 09:20 AM
Is there power to the water valve, dispenser side, when button is pushed ???..............P/N wr57x10051 for the valve............If no power to the valve, is there power out at the dispenser connection??? ............Check the dispenser board for damages......Check connection at top of door hinge.........
#5 kdog
    RoughShod
  • 7,474 posts
Posted 31 October 2012 - 09:06 PM
Did you read the second link ???
#6 clancy
clancy
    Ikkō-ikki
  • 20 posts
Posted 02 November 2012 - 12:19 PM
OK My bad thanks for the link I guess I needed to read the whole thing. I did check valve assembly when the unit is unplugged I and the dispense button pushed I get continuaty across the relay and with power on I get 120 volt out. I disconnected the water connection at the valve and I still do not get any water. I am going to get a new valve assembly unless someone has a better idea. I am thinking it is a mechanical issue with valve.
#7 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 02 November 2012 - 12:35 PM
... bottom of door there is a connection there I broke the connection and water is there.
... I disconnected the water connection at the valve and I still do not get any water.
#8 clancy
clancy
    Ikkō-ikki
  • 20 posts
Posted 02 November 2012 - 12:50 PM
Yes I did say ealier there was water there that must have been residual water as there was no pressure. I Thought there was water before the door but no there is not
#9 RegUS_PatOff
  • 33,588 posts
Posted 02 November 2012 - 01:31 PM
... with power on I get 120 volt ...
with the Valve wires still connected ?
http://www.repaircli...tDetail/1032629
Water-Inlet-Valve-WR57X10051-00893190.jp
#10 clancy
clancy
    Ikkō-ikki
  • 20 posts
Posted 02 November 2012 - 02:31 PM
NO I got the 120 with the valve wires connected it is a disconnect plug.
#11 RegUS_PatOff
  • 33,588 posts
Posted 02 November 2012 - 05:37 PM
... with the valve wires connected it is a disconnect plug.
? ? ? say what ?
all voltages should be measured with the devices connected,
unless otherwise specified.
if needed:
http://www.repaircli...PartDetail/2004
Dispenser-Control-Board-WR55X129-0081349
#12 DurhamAppliance
    Sho' Nuff Chozin
  • 6,073 posts
Posted 02 November 2012 - 09:00 PM
Have to ask the obvious as I don't think i read anything discussing it but is there water(with sufficient pressure) entering the valve? If so, and nothing comes out of the valve after energizing it with 120 VAC then replace valve.
www.DurhamApplianceThrift.com
