KitchenAid washer KAWE760W
#1
Posted 31 October 2012 - 08:24 AM
#2
Posted 31 October 2012 - 12:55 PM
are you sure ?... Lid switch tests OK
... missing (3) characters at the end of your model number...
- kdog likes this
#3
Posted 31 October 2012 - 01:37 PM
#4
Posted 31 October 2012 - 02:11 PM
IF the Lid Switch, Actuator, and wiring is OK,
then the Timer would seem to be bad
http://www.repaircli...PartDetail/3406
http://www.repaircli...PartDetail/3010
http://www.repaircli...PartDetail/1170
- kdog likes this
#5
Posted 31 October 2012 - 03:51 PM
Eric
#6
Posted 31 October 2012 - 07:20 PM
Common problem with these washers is an open neutral at the motor connection. Check the white wire where it connects to the motor connector and look for another connection in the harness near the motor.
- kdog likes this
#7
Posted 31 October 2012 - 07:42 PM
#8
Posted 31 October 2012 - 07:48 PM
according to the Tech Sheet, the Timer Motor is connected directly to Neutral.... Neutral from the power plug goes to the motor first, thru the overload trip in the motor and then back out the white/black wire to the timer motor
If the Timer is good, during the Wash Cycle, there should be 120v between one side of the Lid Switch to chassis (a good ground)
and 120v across the two wires on the Lid Switch
- kdog likes this
#9
Posted 31 October 2012 - 08:48 PM
#10
Posted 31 October 2012 - 08:55 PM
What's the fix?
Female wire terminal - motor
This one would likely work also:
http://www.repaircli.../T20021/1810275
#11
Posted 31 October 2012 - 09:01 PM
#12
Posted 31 October 2012 - 10:26 PM
Don't think that is the correct tech sheet. This washer uses the 3-speed motor, that schematic shows a single speed motor. I don't have the tech sheet for this model so can't say for sure about neutral connection. According to Whirlpool parts site, the tech sheet number is 3353753.
Eric
Edited by fairbank56, 31 October 2012 - 10:33 PM.
#13
Posted 01 November 2012 - 03:15 AM
Yes, I see that now, you're right,... This washer uses the 3-speed motor
... According to Whirlpool parts site, the tech sheet number is 3353753
although the 3353753 tech sheet can't be found at Whirlpool service website
Whirlpool service site lists:
KAWE760WAL0 Tech Sheet # 3352953
KAWE760WAL1 Tech Sheet # 3352953
KAWE760WAL2 Tech Sheet # 3352953
KAWE760WAL3 Tech Sheet # 3353757
KAWE760WWH0 Tech Sheet # 3352953
KAWE760WWH1 Tech Sheet # 3352953
KAWE760WWH2 Tech Sheet # 3352953
KAWE760WWH3 Tech Sheet # 3353757
3352953 shows a 1 speed Motor
3353757 shows a 3 speed Motor
but they both show the Timer connected directly to Neutral
Check for 120v between one side of the Lid Switch to chassis (a good ground)
#14
Posted 01 November 2012 - 09:17 AM
The only time you would have 120vac "across" the lid switch is if it's open and your in drain/spin mode (timer contact #2 closed). The lid switch has no effect during fill and agitate. At least, according to the schematic. There are many variations in Whirlpool wiring schemes. Some even have the lid switch in the neutral side before the motor. Here's a Whirlpool schematic for 3-speed motor showing neutral feed to timer going through motor. Gotta have those tech sheets for the specific washer to know for sure what your dealing with.
Eric
#15
Posted 01 November 2012 - 11:22 AM
#16
Posted 01 November 2012 - 11:42 AM
#17
Posted 01 November 2012 - 12:19 PM
Eric
Edited by fairbank56, 01 November 2012 - 12:25 PM.
#18
Posted 01 November 2012 - 01:24 PM
#19
Posted 01 November 2012 - 02:15 PM
Well, this is a bit strange. After inspecting the timer, lid swith & checking motor...buttoned it all back up and...seems to work fine now.
Probably a receded wire in the timer harness molex connector.
