Secret Samurai Technique For Checking The Drum Bearings In A Front Load Washer
front load washer bearings test noise
1 reply to this topic
#1 Samurai Appliance Repair Man
  • 24,232 posts
Posted 01 November 2012 - 04:39 AM
In this coveted and cherished video, Samurai Appliance Repair Man shares with you his secret kata for checking the drums bearings in a front load washer to determine if they are bad or not. Using this technique can save both you and your customer much gastrointestinal disturbance, weeping, and gnashing of teeth. For example, you could go through the trouble and expense of replacing the drain pump because the washer wasn't draining only to find that now it is very noisy when it goes into high-speed spin, indicating bad drum bearings. Wouldn't it have been nice if you knew that at the outset?
You can find whatever appliance part you need through the parts search box right here at The Appliantology Academy. No harm in buying and trying with our 365-day, no-hassle return policy, even on electrical parts that were installed!
Subscribe to our FREE, award-winning newsletter, Appliantology: The Oracle of Appliance Enlightenment ==> http://newsletter.appliantology.org and download your free report on appliance brand recommendations! Every issue is jam-packed with appliance repair tips and inside information direct from the Samurai's fingertips to your engorged and tingling eyeballs.
The Appliance Guru provides prompt, convenient service in the following towns in New Hampshire: New London, Elkins, Wilmot, Springfield, Georges Mills, Sunapee, Mt. Sunapee, Newbury, Sutton, Bradford, Warner, Grantham, and the Eastman Community. Visit our website for more info and a discount coupon on your next service call ==> http://applianceguru.com
#2 jumptrout
jumptrout
  • 1,130 posts
  • Flavorite Brew:Coors Light
Posted 01 November 2012 - 09:08 AM
Good info. I use the same technique on large commercial laundry equipment including the dryers.
