DBXR463EG0WW ELEC DRYER wont stop!
5 replies to this topic
#1 Volkemon
Volkemon
    Sōhei
  • Master Appliantologist
  • 109 posts
  • Flavorite Brew:IceHouse
Posted 02 November 2012 - 08:46 AM
Greetings to the Dojo!
I have been away for some time, and helping the current appliance manager.
We have a GE electric dryer that will not shut off in the More Dry/Less Dry modes. Timed works fine.
The timer switch was replaced, as was Humidity detector, OH sensor and Temp sensor all replaced. What tells the timer to advance during the 'More Dry ' cycle?
Many Thanks.
Onward and Upward!
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,463 posts
  • Flavorite Brew:Killians Red
Posted 02 November 2012 - 09:31 AM
The auto cycle only advances on these when the heat cycles off...as determined by the cycling Tstat.
most commonly, I find one stage of the two stage element has failed, thusly, the Tstat never gets satisfied and never gives power to the timer motor to advance.
Need to get your peepers on the heater element...a failure will be pretty evident.
#3 RegUS_PatOff
  • 30,201 posts
Posted 02 November 2012 - 11:36 AM
http://www.repaircli...rtDetail/844418
#4 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,463 posts
Posted 02 November 2012 - 03:03 PM
Thanks Reg!
#5 Volkemon
Volkemon
    Sōhei
  • 109 posts
Posted 05 December 2012 - 09:58 AM
Thanks guys for all your help! greatly appreciated!
Onward and Upward!
#6 Volkemon
Volkemon
    Sōhei
  • 109 posts
Posted 02 January 2013 - 10:46 AM
Sorry for the late follow up... Sure enough, it was the heater element. MANY thanks to all! Domo Arigato!!
EDIT: at home relaxed now...  BIG thanks to
KurtiusInterupptus           :rocker:
for the GREAT explanation of the timer advance.
Edited by Volkemon, 04 January 2013 - 04:13 PM.
Onward and Upward!
